Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My internet speed is slow.I connect it via bluetooth.
I use internet via bluetooth and phone as modem but speed is slow comparing to the broadband connection.why? How can I increase its speed while using the phone as modem?
Anonymous
Level 2:
Sniper:
  • Expert 89 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
89
Questions
0
Helped
29882
Points
191
You visit this link tips to increasespeedThis link contains the tips about the increase the speed of the internet.you can check Your internet speed in the site ipdetails
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
6379
Points
92
By any means even if the configuration of the system is also very good but still with the bluetooth you will not get the connectctivity speed like the broadband and that is same as with the wireless also you will not get the speed like you get from the broadband connection . as this is just the virtual connection with just give you the emergency support not like as usual cbroadband connectivity.
so that cannot be increased .
Anonymous
Level 2:
New Friend:
  • Expert 159 Answers
  • Posted on Oct 28, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
159
Questions
0
Helped
61848
Points
279
You may check the internet speed test.......
Anonymous
Level 3:
  • Master 961 Answers
  • Posted on Feb 28, 2011
Anonymous
Master
Level 3:
Answers
961
Questions
0
Helped
250544
Points
2657
Follow
ashishbhatia answer...
Sir i can't take large files via bluetooth & download bcos of my phone memry is low my internet speed is also slow plz help me. Rply plz....
Hello there,
The phone comes with a low memory size that is why it is not receiving large files from other devices via bluetooth. What you should do is to try to get an additional memory card and install into the phone, then when you receive files via bluetooth, you should send them to the memory card.
For the internet that is slow to connect, the problem is not from the phone, it is from the network of the sim card service provider. It tends to be slow on some kind of phones with low memory capacity to read internet faster.
Insert a memory card into the phone and try to move all files on it, then you can surf the internet using ur phone with an improved internet speed.
Hope this helped.
Goodluck
Elect_Comp
tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 • Computers & Internet
3helpful
2answers
Can i get the speed internet browsing using mobile as a modem
yes of course.. connect your mobile to the computer via connectivity cable, blue tooth or infrared. setup a new connection and enjoy.
note: you need to get access point settings from your network carrier. for further problem you will have to cantact your customer care of your network carrier and get help from them since all the carriers have different settings..
2answers
What is difference between lan card and modem
The difference between a Lsn Card and a modem are this - A Lan card is a card that you slide into the side of a laptop and it can allow you the ability to get onto a network wirelessly. A Lan card for a PC allows a Lan connection by way of a CAT 5 cable that will allow you to get onto the internet or if a crossover cable is attached to your pc to another you are directly connected to the network. A modem is a piece of hardware that is installed into a slot in the PC that will allow you the ability to get onto the internet by attaching a phone line to it through the RJ 11 jack (which it comes with 2 rj11 jacks on it).
Here is the picture of LAN port and Modem port
My mobile is nokia 5800 music express. so i want to connect internet through my pc
First of all, install the Noki Pc suite on your computer, connect the phone in Nokia Mode, you'll see that your mobile is a Modem, Open the Internet Connection and set your nokia modem as the default modem, create a dial up connection using the Internet Connection wizard, you'll need the number to dial, this number is to be obtained from the Network Operator. Now you can connect to the internet using your phone. Note that the speed will be slow as compared to normal (wired/wireless) internet connection. Good luck Thanks for using FixYa.
Connection is slow
the internet connection it's slow?
try to go to www.speedtest.net
run a test if it's a lot lower than the speed you're paying for make sure you dont have a splitter or filter between the modem and the jack.
if you dont replace the phonecable
powercycle to the modem.
if stills doesnt help connect the modem straight to the pc without the router.
if the speed its a lot faster its going to be a problem with the router, if the problem persist contacn you internet service provider.
1helpful
2answers
I used to connect to the internet using pipex broadband and a speedtouch 330 usb modem. I purchased a belkin N f5z0103ukn wireless modem router and after much reconfiguring and sheer guess work i could...
Hi,you can check your original internet speed with upload and download exact speed at free of cost,for this facility i am using this http://www.ip-details.com/ site.visit here for more details ,it is a total free site.
I have 6mbps speed but my speed get too slow on my modem. so how can i improve my speed.
is that a phone modem
this are conventional speeds expected:
  • Conventional Ethernet can transmit data at rates from 10 Mbps up to 100 Mbps.
  • Phoneline networking specification, HomePNA 2.0, transmits data at rates up to 10 Mbps.
  • One type of powerline networking technology promises data speeds up to 189 Mbps.
  • Wireless Ethernet has data transmission rates up to 11 Mbps.
  • HomeRF goes up to 1.6 Mbps.
  • Bluetooth goes up to 3 Mbps.
the speeds noted above are theoretical as other factors WILL affect your connection speed and WILL LIKELY lower the connection speed between your device and the ISP.
for comparison check on www.speedtest.net and compare other isp, changing isp is your more concret solution.
Please tell me what my modem is for a intel insider windows 2000
A modem that is on its own card in a computer is for dialup access to internet, via telephone lines. Other modems that do the same thing are built in to laptop computers, and always have a regular telephone-type plug on gthe computer. Dialup access is notoriously slow compared to Broadband (Cable/DSL) connections.
1helpful
Adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
