After I added freon to my car, the compressor cuts out rapidly...I may have added too much Freon?
SOURCE: AC Compressor will not engage
To reset the ac system,remove negative battery terminal for 20 seconds,then put it back on.
SOURCE: 2002 Saturn not cooling
well you cant just put refrigerant into a system. 1st you had a broken line . so the compressor probally pumped all its oil out and you lost the gas. 2 after such an incident you have to have the system evacuated to remove all the air out of the lines and system. if there is any air or moisture in there it will not run right due to freezing and without oil in there you will destry your pump . i suggest that you take it to a garage and get it evacuated be fore you proceed. then you can refill it. also on your vechile it should tell you how much goes in there like 1lb 6oz and there is an amount written on the can so go by that. putting more in there will do more harm then good and cause alot of headaches and sweating. good luck have a good day
SOURCE: 1996 impala ss air conditioner compressor is very noisy
That clutch and coil are serviceable without replacing the compressor but I have had little success with this as usually the clutch gets in that shape subsequently from activity going on inside the compressor which means that clutch is failed generally for a reason.replace the compressor -orfice tube-reciever drier and happy motoring......
SOURCE: adding freon to the auto air conditioner, the
On that model,it will cycle on and off while you add freon.If it does not ,then the ac system might have a problem.The low side pressure switch is located on,or near the accumulator .Unplug the switch and take the wire end plug and connect the two plug in`s together(cross it out on the wire).This will make the ac compressor engage and you can charge the system,do not leave the wire connected,plug it back up to switch.If the ac compressor does not come on ,then have the system checked out.
SOURCE: a/c compressor not working added freon but it
Either the system is still low of freon,or the sensor (one of them)is bad.The sensors are on the high side of the system,liquid line.If you will get on chat,I can help you with this,it will take a while,I will need to know how much freon was added.And what the system is doing,is the ac clutch engaging,etc?Ask for ronicon,when you click on chat with,type my name in,roniecon,with your text,that you are writing .
