Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Why is my L7 12" solobaric sound like its breaking wind
I've checked everything the surround isn't torn anywhere. you can actually push on the speaker and it has plenty of movement. please help me is there some special way to wire it.
Posted by jarmour83 on
johnnyraptor
  • 89 Answers
If you have a amp. hooked to it than yes.if your car wires aren't marked than do what i do......turn music on with speakers unhooked hook both wires up to one speaker,if it sounds clear than that's it. if not switch them.and do the same to the other side. hope this helps.
Posted on Mar 26, 2009
Anonymous
  • 39 Answers
This may be caued by the box you have it in also if the dimensions are not right it may sound like ****. Also the location of the box may mess with the sound also. Are you sure you are running the right type of amp? Definantly try what johnnyraptor said also.
No sound tcl 40F S3800
when headphones are plugged in a conection is broken to stop sound coming from speakers try plugging in and out jack plug for headphones a few times
Jan 02, 2017 | Televison & Video
Onkyo surround system. The subwoffer isn't making sound. I've tried all remote settings. No luck though. Any ideas?
Try checking that the wires are properly connected to receiver. Maybe the sub speaker is blown
Mar 12, 2013 | Audio Players & Recorders
My refridgerator isn't cooling I changed the starter relay(thought that was problem) but it still isn't running. I check compressor gets warm but not running
Unfortunately it sounds like your compressor is on its way out. In some cases you can get what's called a "hard start kit" or a "3-1" (same thing) to help force it to run, that does sometimes get you more life out of the compressor. MY GUTT FEELING: The reason it is warm is because it is trying to run but can't, do to a broken winding inside the motor or a piston or valve is jammed or bent. The reason forcing it works sometimes is because it actually breaks pieces off when it is forced so hard. The divit or scratch left behind may continue to break down over time resulting in blockage and seezing, or it may just break a small piece loose and run for years. It is a gamble though. Good luck with it
Jan 17, 2013 | Refrigerators
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
I can't get the sound to work.
You'll have to remove the cover to the microwave, MAKING SURE YOU UNPLUG IT 1ST. Check to see if it has a small speaker for the sounds to work. Take it to an electronics store and have them check to see if it works. IF NOT, replace it with a similar speaker (doesn't have to be exact, just the same voltage and ohms). If that isn't the problem, if the original speaker or device for sound works, then you've got a problem in the circuit board probably, and not worthwhile to replace it.
Sep 20, 2012 | Goldstar MV-1526 Microwave Oven
No sound from Rear Speakers
Ok, so we know the connections are correct, the speakers all work properly.
The only other thing I can think of is: is your PC actually sending signal to the rear speakers? Have you set it to 5.1 surround, and are you playing something in surround sound? The best way of checking (personal preference) is use some kind of racing game, reverse into something and you'll get a broken window effect in the rear speakers.
So, check to see if your PC is sending the rear effects, double check to make sure the actual speakers work (you could plug an MP3 player into the rear speaker input.
If this doesn't help, feel free to reply.
Jan 11, 2010 | Audio Players & Recorders
How do i rebuild a set of solobaric l7 subs 15s
you have to remove the rubber surround holding the front of the subwoofer to the metal frame.the voice coil is a coil of copper wire.you should be able to get it through kicker.its not the easiest thing to do i recomm seeing if kicker can rebuild it for you or try a local speaker repair shop theres not alot of them but you can find them.first get the rebuild kit if your going to do it.it should show you everything you need to do. if you need more help let me know [email protected]
Oct 08, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Why is my L7 12" *******
Get a volt meter and check the resistance from the positive pole to the negative. There should be at least 2 ohms or 4 ohms depending on the model you have. No reading at all? Check the leads under the terminals - are they still connected? Does the voltmeter read 0 or no ohms- then the voice coil is shorted out and should be repaired or replaced.
-Dynami
Mar 26, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
I have an Harman kardon receiver (avr 310) it only plays in left and rigth speaker with surround off . I try everything to make it work in other but it can't .
Surround only works from a surround source such as Pro Logic.
If you are useing a regular stereo source with surround off, the sound will come only from L/R speakers (and sub woofer if used)
Apr 22, 2008 | Audio Players & Recorders
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
135 people viewed this question
Top Kicker Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
