Question about Lexmark X75 All-In-One InkJet Printer
You must be trying to run the programme, instead you should remove the printer and connect to another usb port and when the printer is found, it will ask for the driver, at which point you choose to install the driver manually and not automatic and point windows to the folder in which you have the driver downloaded, but if it is a zip file ensure you unzip it first.
Posted on Aug 24, 2007
I found this possible solutions for your problem. Most likely some software installation has messed with the file Scrrun.dll and possibly other WSH files in folder windows\system32, or it's registration. 1)It may not be registered properly. From Start/Run, type regsvr32 %SystemRoot%\system32\scrrun.dll You should now get this message box: --------------------------- RegSvr32 --------------------------- DllRegisterServer in C:\Winnt\system32\scrrun.dll succeeded. --------------------------- OK --------------------------- 2)If this doesn't solve your problem, download and install WSH 5.6 from here: http://msdn.micr- osoft.com/nhp/Default.asp?contentid=28001169
it says its not a specified path and iam not authorised to use it thanks for trying.
