I just got my projector out of storage, changed bulb. After 3 hours of viewing, image appears with dark spot in middle of screen. Thought it was bulb but put in different bulb same problem. Its as if there is a finger blocking the lens in middle third, or something. Its the same on all projections. Any suggestions? Thanks k
SOURCE: My projector is shooting a yellowish brown color in the middle left of the screen.
Hello
Pls check for the Fly-Eye lens in the optical unit.Also service the
LCD panels.
Viren
Rave Services
Chandigarh, India
SOURCE: Sharp XR10X Screen size
depending on the age of your computer, some of the older video cards in XP only will allow you to show video in 600x800 resolution. When you want to show video go ahead and change both of your display properties (both the primary and the secondary) to 600x800. See if that works.
If that is not what you are refering to go right click on your desktop and look for the properties or settings of your graphics card. it may say graphics properties . In that area there will be tons of options like (when showing video only show it on the secondary monitor) play around with the different settings on your graphics card.
Good luck
SOURCE: sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
[email protected]..
SOURCE: Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
