Question about La Crosse Measuring Tools & Sensors
Outside temperature sensor not working
The outside temp is not showing
Posted by Mary Ellen... on
Tom Chichester
    Top Expert:
  • La Crosse Master
  • 55,958 Answers
You probably need to replace the batteries. Be sure to follow the LaCrosse instructions exactly to get your Weather Forecaster working properly again
Posted on Jun 30, 2013
BAR888A -Changed batteries house (1st) & outside unit(2nd.) Now inside unit not receiving signal. Only thing registering is inside temp. Outside unit is also showing temp.
Remove all batteries. Install batteries in outside unit and allow time for it to begin sending temperature. Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit could be defective.
Sep 25, 2018 | Measuring Tools & Sensors
The outside temp won't show up on my new weather station
  • Remove all batteries
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Remove batteries from both units
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
Ambient air sensor on 2005 Chrysler Town and Country showing -40
I would suspect the outise air temp sensor is defective, replace it. It is located in front of the AC condensor core.
Jul 19, 2012 | Cars & Trucks
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
99 oldsmobile intrigue
The ambient temperature sensor going bad causes this exact problem. I've replaced many of them because when they show outside temp as being below 60 degrees, the A/C control module will shut the compressor off.
Aug 07, 2008 | 1999 Oldsmobile Intrigue
Temperature guage
Right behind the grill around the rad. support on the passenger side (usually) there is a sensor called an ambient temperature sensor. That gives your outside temp. on your rearview mirror.
May 15, 2008 | 2003 Chevrolet Suburban 1500
Measuring Tools & Sensors Logo
2,222 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
