I have hair and particles on the internal sensor on my NIkon D-70.Please tell me how to clean the sensor by myself. thanks you!
You must have dusty mirror box area. Here is what you should do. 1. Remove lens from the body. 2. Blow out any dust from the mirror box area using can duster (careful not to spew out liquid). 3. go to menu and select mirror up or ccd clean mode. You can also set at manual shutter speed "B" and hold up the mirror. 4. Blow out dusts over the CCD sensor (Do Not Use can air! If any liquid sprayed on CCD the cleaning gets worse) so use Hand-squeezee air bulb. You can purchase one from any camera stores.) 5. test shots and repeat. 6. If this procedure did not resolve the removal of the dust, you can purchase a cleaning solution package and try it. I do not recommend it becasue our techs get lots of cleaning requests from these package. Remember, if you are using these solution, 1. Never give any pressure to the screen, just tissuie touch pressure only. 2. move circular motion as you mouth blow the air as you move. complete the motion exiting through the corner of the screen. Did not work? send it to repair techinician! Our tech cleans it for $49. 24 hour turn around and also checks the camera too. Good Luck
