Question about Philips Coffee Makers & Espresso Machines
My philips senseo new generation won't open I suspect a vacuum-problem but don't know how to solve this can you advise me?
Posted by threewhf on
Anonymous
Eureka! I have solved this problem.
Disconnect your Senseo from the power. Take it to the sink. Hold it upside down and put hot water in the coffee outled. In less than 30 seconds the senseo will open.
The problem with Senseo is that - especially with coffee holders for 2 cups and chocolate - after making the coffee, the pod holder and the pod cool down. This creates an underpressure, that prevents you opening the Senseo. Hot water will increase the pressure and then you can open the senseo very soon.
This solution was found in despair after struggling with all the complex tool involving (knives, pumps, etc.)
Let me know if it works for you
Hans Beers ([email protected]).
Posted on Aug 08, 2009
  • Eddie freeman Sep 11, 2013
    Great. Yes it works
Need to replace the Senseo power cord. How do I open the bottom up?
Contact Philips customer support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Apr 11, 2015 | Philips Senseo HD-7810 Coffee Maker
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo HD7832 Calc Cleanup
This model of Senseo suggest cleaning once every 3 months, preferably 4 to 6 times a year.
I suggest to download the user manual from Philips for your model and to follow the procedure described.
Jun 12, 2009 | Philips Senseo HD7832 Coffee Maker
My Senseo coffeemaker 7810/15 leaks water out of the spigot all over the counter.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Jan 25, 2009 | Philips Senseo HD-7810 Coffee Maker
One coffee cup button switch not wotking properly after 6 months
Jan 24, 2009 | Philips Senseo HD-7810 Coffee Maker
Lid is stuck shut on my senseo
I just had this same problem. The seal is stuck and might have coffee jammed in it. I unplugged it. Then I pushed down on the lid and pulled up at the same time. It opened for me. I hope this helps.
Dec 08, 2008 | Philips Senseo HD7832 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo stuck after using coffee pods that have "milk" built in....5 days later
I had the same problem. I waited for a while as the instruction says but didn't open. But, I got it open!!! by turning and slightly pulling a small plug behind the water tank on the backside. (remove the water tank then you'll see the little plug. see attached photos) I think it will let air in and vacuum seal get released. After it opened, I gently turned the plug back and push it in as it was. Now, it is running perfectly again. I just had a great coffee. :-)
58c3f6de-9c9e-437e-b419-0533bdf0a452.jpg562b78da-5cdf-43fe-afb9-546e2ba78530.jpgb5d600f7-721a-4b74-a954-ef849424bf28.jpg
May 14, 2008 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
6,132 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Ross Keen
Piers Carter
Piers Carter
Harrie
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
