Question about Nissan Vehicle Parts & Accessories
Secuity system light stays red and drains battery
After recharging my 2000 Maxima's battery because I hadn't driven it because of ice, I reconnected it as usual. At that time I did'nt notice that the secuity system light stopped flashing and stayed red. A few days later the battery was drained. I had the battery checked with the crank test and it is in great shape. How do I reset the security system?
Posted by bluethund195 on
Eric Heifetz
  • 607 Answers
Switch toggle switch with ignition ON , Sounds like it it is on the VALET mode
Posted on Mar 26, 2009
Battery light stays on
That generally indicates that the battery is bot being recharged. You need to have the charging system tested in the vehicle to find out.
Aug 07, 2014 | 2000 Ford F250 Super Duty Crew Cabs
Why does my 2000 nissan maxima looses power while driving
Sounds like the maf sensor. Im assuming its throwing a check engine light? Get it read at AutoZone and look up the code. Go from tjefe
Jun 03, 2014 | 2000 Nissan Maxima
2000 MONTE CARLO BLINKERS DO NT WORK,AC/AND HEAT DO NT WORK,AND RADIO IS SAYING LOCKED UP
Does the vehicle start?
If not, then check battery voltage. If below 12.5 volts, then recharge the battery and retest system charging voltage (should be around 14 volts)
If battery is fine and vehicle starts, then check fuse box and wiring loom connectors.
Nov 13, 2012 | Chevrolet Cars & Trucks
Power steering fluid leaking and there is a whining noise along with a rattling sound on my 2000 Nissan Maxima.
Doesn't matter you have a leak
You should have stopped using it
when you first noticed the leak & had
it resolved,now you may need a new pump
Oct 08, 2012 | 2000 Nissan Maxima
Acts like dead battery, jump starts, and can drive, but turn on the a/c and whole thing dies and I have to coast to parking and jump start again. any ideas?
you need to check the charging system voltage if the alternator is not putting out voltage the car is only running off the battery and the battery is not being recharged turning on the ac adds the drain from the cooing fan about 30amps and the blower motor inside the car another 20 amps and also the compressor clutch of 20 amps
Aug 17, 2012 | 2000 Nissan Maxima
Why does battery go weak even when not using the car?
possibly the mileage driven does not allow the battery to recoup the charge it used up in starting the car. perform a draw down test to see if battery is defective
Aug 16, 2012 | 1988 Nissan Maxima
How to reset alarm or fuel pump?
Disconnect the battery, turn everything on and then off. Reconnect battery after 30 minutes. Should reset ECM.
Apr 22, 2012 | 2000 Nissan Maxima
Humming sound during start-up from Nissan Maxima GLE 199
Sounds like your alternator is out. Did you do and electrical system check since you replaced the battery?
Feb 02, 2018 | 1999 Nissan Maxima
Hie, I Have got a crate tx 15 and, I have a sound problem, all time I have got a buzzzz... but there another thing too, the led for the battery recharge does'nt light and when I plug the electric...
Your symptoms would indicate the battery is defective. When a battery fails, its internal resistance goes up and they PROBABLY use this battery in place of having a separate filter capacitor so you will get hum or buzz as a result and no charging indication.
Sep 13, 2011 | Crate TX15 15W Guitar Amplifier
Vehicle Parts & Accessories Logo
416 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Kardoc
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
