EXPERIENCING PROBLEMS WITH LOADING MY M AUDIO DELTA INTO THE DEVICE MANAGER. IT STATES CHANNEL 0/0COULD NOT BE SET ON ASIO DRIVER DELTA ASIO!
ALSO WHEN I TRY TO LOAD THE ASIO MULTIMEDIA DRIVER, I GET A POP-UP STATING THAT ITS (ASIOMME.DLL) IS ALREADY RUNNING. AFTER THAT POP-UP IS CLEAR I GET A MESSAGE STATING THAT THE ASIO DRIVER ASIO MULTIMEDIA DRIVER COULD NOT BE LOADED.
IM VERY CLUELESS AT THIS POINT. CAN SOMEONE HELP ME.
SOURCE: SOUND PROBLEM
* i think you haven't register o.s
* if o.s is register it will not support some drivers to be installed
SOURCE: multimedia audio controller device driver
have you always had this problem
when did it start
does driver show in device manager
when there is a yellow question mark on a device , it means the device is detected but unknown, but if there is question mark and exclamation mark on it, it means it is recognised but no driver to make it work.
SOURCE: popping and clicking in delta 1010 playback
frequency response:
20Hz-22kHz, +/-0.3dB
dynamic range (A-weighted):
109dB (A/D), 117dB (D/A)
signal-to-noise ratio (A-weighted):
-109 dB (A/D), -117dB (D/A)
I found these on the site, seems you have the khz way too high.
All good.
Here's the link to your site.
SOURCE: hi i've just done a clean install of windows xp on
You can get them here
http://www-307.ibm.com/pc/support/site.wss/MIGR-55386.html
