Question about HTC Computers & Internet
Htc troubleshooting Signal bars have no signal on my htc vivid phone. I did a factory reset and soft reset and it still has a x mark above the signal bars. I went into mobile network and click on it and it didn't do anything. I had SIM card replaced but still no signal at all. What else can I do?
5 Related Answers
Anonymous
SOURCE: Windows Mobile 6 Won't Boot
bigsphinx, I too am having the exact same problem on both my phone and my wife's too, about once a month it just locks up then after a soft reset it just gets stuck on the green screen. I called support and they said I just have to do a hard reset, which loses everything :(
So for now I always backup (using PIMBackup) to my SD card for the next time it happens.
Posted on Aug 27, 2008
Anonymous
  • 16 Answers
SOURCE: GPS Signal low
ensure you update quickgps in programs menu every 6 days to ensure best gps reception
Posted on Mar 04, 2009
a7878
  • 502 Answers
SOURCE: HTC G1 dead, can't power on, factory reset/soft reset not working
Well try to get your hands on either a second G1 phone or a multimeter to rule out a battery issue. If you take a charged battery from another G1 and it still doesn't turn on you will have a logic board issue. With a multimeter you can measure the battery directly, if the phones doesn't turn on if the voltage is over 3.7V, you'll have a logic board issue as well. Within one year T-Mobile should give you a replacement. If you can't get a replacement under warranty there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, If you try a self-repair make sure you feel comfortable with opening devices that are not meant to be user serviceable.
Posted on May 17, 2009
issikiki
Naajiyah Auladin
  • 563 Answers
SOURCE: the phone loses signal very often and then the battery dies
This might be the battery problem. Try to change your battery with a new one.
Posted on Jul 27, 2009
Anonymous
  • 5 Answers
SOURCE: htc p2450 touch signal reception problem
soft reset then select network mannualy.
Posted on Sep 17, 2009
Power button wont turn
Soft reset by removing the battery, wait 20 seconds and reinsert.
If this does not solve the problem...
1. Remove the battery, wait for a few seconds, then reinsert the battery to turn off your Merge.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If none of this works, get a new phone, hopefully you have the insurance.
Dec 17, 2013 | HTC Cell Phones
My htc vivid keeps crashing and reboots already have performed factory reset a few times still n/g
try custom ROM from XDA forums. Google for it. Laos, be sure your phone is not under warranty. You cannot claim warranty for it later. This should definitely work.
Oct 22, 2013 | HTC Vivid
UNDO A FACTORY RESET?
no known ways because factory settings means permenant delete for files
May 24, 2013 | HTC Vivid
How do you factory reset HTC Vivid?
Dear:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 16, 2012 | HTC Vivid
My keyboard on my htc vivid phone wont come up
Go to setting then go to storage then go factory data reset.... then your keyboard will come back on your htc vivid phone will come back cause i just did it
Aug 07, 2012 | HTC Vivid
My HTC HD2 wont start, showed error with "cprog.exe" I'v tryed soft start, tokk out batary, but now I onslu come to HTC picture when starting up,, no buttons is function..
I'm sorry, but I think you will need to contact T-Mobile for support. Call them from another phone at 1-800-T-Mobile.
If you don't care much about the info on the phone, then do a hard reset to factory defaults.
http://www.hard-reset.com/htc-hd2-leo-hard-reset.html
CAUTION - DOING A HARD RESET, YOU WILL LOSE EVERYTHING ON YOUR PHONE. REMOVE THE MEMORY CARD BEFORE DOING A HARD RESET.
Good Luck,
Mark
Apr 22, 2011 | HTC HD2 Smartphone
I put my password but it doesnt work i have htc hd2
Good Luck,
Mark
Apr 17, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc p2450 touch signal reception problem
Sep 17, 2009 | HTC Touch P3450 Smartphone
Signal
First thing ensure that the TomTom is fullly charged using the home charger.
Press the small reset button on the base (700) or do a factory reset.
The other thing to try is tap the GPS signal bars to go to the configure and check in the top right hand corner there is a circle with yellow and black esgments if this is moving then your TomTom is looking for a signal. Move around and you should find that the bars at the bottom will start to move and the small screen on the right will start to indicate circles. When the bars start to move you are getting GPS signals when the bars change to blue there you have a coordination for your position. Some areas are worse than others so move out of your house if after doing above does not get a signal
Aug 14, 2008 | Tomtom ONE 3rd Edition GPS
Computers & Internet Logo
27 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
