SOURCE: how did my pictures get deleted by formatting the card?
When your camera said the card needed formatting that meant that it needed to be erased. So when you clicked continue you basially said yes to the formatting command and it went and erased all of your pictures. There is nothing that can be done. Once you erase or format your pictures they are gone. I have recommended to many that own digital camera's with memory cards to purchase a card reader. You can get them just about anyplace that sells camera's and camera accessories. They cost around $20 and may even be running less now. You plug the card reader into your computer and insert your card. You can then transfer all your photos onto your computer and save them there or if you have a CD burner you can put them on CD. I am sorry to have to be the bearer of bad news.
SOURCE: formatting memory card
Sir/Madam,
At first, you need to copy all images from the Memory card to a PC using a card reader.
and Second, you can format your card.
It will save your images and you card may be in working condition.
SOURCE: I inserted a new SD
Make sure the slide switch on the side of the card is in the unlocked position. Also, be sure this is an SD card, not an SDHC which your camera cannot use.
