Question about Bissell Vacuums
Model 8804 t
Water not coming out
Posted by Jack Tanski on
Bissell
  • Official Brand Answer
  • 315 Answers
Hello Jack. Not having the machine spray when you're ready to use it is frustrating and I'm sorry you're experiencing difficulty.
Here's a quick link to the our complete troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Posted on Jul 09, 2013
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Powersteamer 1697, 8804 series, Smartmix will not despense cleaning solution
there is usually a button or release lever by the handle that u sqeeze to release salution
Jan 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
The water and shampoowon't come out but it cames
This model is famous for burning up the silinoid switch that allows the water to come out the bottom to clean the floors. That will need to be replaced, but my recommendations is to take this model back and bet your money back. It is engineered bad!
Nov 25, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
No water/cleaning solution comes out on wash cycle
With this model, the soap dispensed is controlled by electric solenoids. these can be tricky to troubleshoot. I would take it to your nearest dealer. these solenoids fail, and cause a variety of symptoms.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 08, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
No water comes out when you press the trigger only solution comes out when you turn it on its side
Check the belts. Most models have two belts. The first one from the motor runs both the brushes and the water pump.
Oct 02, 2009 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
41 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
