Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Wrench flashes 6 times then 6 more continuosly
When flashing there is no mobility. have turned off and on and it will work for a few feet and then come on again.
Posted by gord mcrae on
rufus jackson
    New Friend:
One red light flashes continusly and chair won't charge
Posted on Jan 02, 2014
What is problem with my rascal 305 four wheel scooter
your problem is related to the overload breaker on the chair you need to figure out why the breaker is tripping either due to batteries going bad or the brushes in the motor need adjusting or replaced , also you need to check the automatic brake is releasing completly a dragging brake will cause the auto reset breaker to trip
Oct 01, 2014 | Health & Beauty
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
www.gewizrepairs.co.uk
Jul 05, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Wrench lite comes on and scooter will not move. I have checked the electric hook ups, all OK. I wiggled the control stick and it move for just a few feet. What could it be?
The wrench light indicates a problem count the number of flashes ie 4 flashes pause 4 flashes indicate a motor problem See my tips on flash codes. Once you get the flash code then you will have to get the chair repaired because there is no self fix for those errors Hope this helps
Jun 10, 2011 | Electric Mobility Invacare Pronto M41...
A wrench light is on the indicator and the chair will not drive. Help! Thanks, Michael
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
May 31, 2011 | Electric Mobility Invacare Pronto M41...
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
445 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
