Programming procedure is so much to type in here. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over
2250 posts now. All are related to
electronic equipment repair help.
Search the site by 'Timeslide' option.
It will make search easy. Or,
type in the brand name to your device into its search box, and press "Enter"
look for bad capacitors on power board bad caps will have swollen tops instead of flat tops replace with same value try to get high temp caps as they go bad from heat
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
