SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
SOURCE: I have a Cisnet C-28
Read the Cisnet AC adapter. It should say input:120-240V, 50-60Hz to work with 240v power anywhere in the world. You just need an outlet adapter for the country you're in.
Testimonial: "He got it right!"
SOURCE: acer aspire L100
it have to be like in this pics:
http://www.virtual-hideout.net/reviews/RaidSonic_ICYBOX/images/30.JPG
SOURCE: acer desktop and Dell monitor
you might have the resolution to high or to low it may be out of range check with another monitor
SOURCE: new ACER ASX3200/8450 Desktop PC DVD/CD not woking
Hi.
Either the drive is faulty (yes, they fail right from new more often than you would think), or the master slave jumper may not be set correctly on the back of the drive. If the PC came fully assembled, I would take it back and get the tech to check it. If you setup the hardware side of it yourself, check that the jumper is correct for the master/ slave situtation of the drive and make sure the cables are pressed in firmly.
Mark
