Sony KP-46WT510 46" Rear Projection HDTV Logo
Posted on Aug 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen Flashes My TV is close to 4 years old now, and the picture is great for 99% of the time but recently, I started having problems with it, when I'm watching TV it ocasionally flashed black or white for a split second, does any one know what is the problem?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 346 Answers
  • Posted on Nov 24, 2007
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
346
Questions
Helped
91564
Points
559
1helpful
LED tv has no picture and flashes on every few seconds
You have a bad panel (TV SCREEN). The LEDs are not coming on. You will have to replace all LEDS, and this can be very time consuming. The LEDs can be tough to find and buy. Many TV parts store are out of stock. Thanks for asking, Matt of Martins TV.
I have 36in rca tv from 99 and my tv screen keeps blinking.
Might be a power supply/transformer problem. With the prices of TV's as low as they are today, it is probably more cost effective to replace rather than repair. I just recently bought a 40" HD flat screen with all the bells and whistles for $299. It would probably cost you close to that to repair your 15 year old unit. Food for thought.
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
1helpful
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
1helpful
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
1helpful
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
6helpful
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
8helpful
2answers
Daytek DT3220 power button flashes green 4 (5) times, no picture
The power supply voltages might look good on an oscilliscope or using a DC meter, but that doesn't really tell you if the supply is good.
Your TV has an unusual symptom, however 99% of the problems on these TVs are caused by the power supply. I have had 3220s that won't power on, the remote or controls on the TV won't work, or the unit blanks out and all sorts of other odd problems. The power supply can test fine, but if you substitute it the TV will work fine.
Sorry to say you're up a creek. The good news is that just about any 5,12,24V power supply for a 32:" TV will work if you are comfortable rewiring the connectors. I have done this a few times and rescued the TVs from an early grave (I'm actually just about to start on another one now). The pinout is written on the board, and make sure the power supply you want to use also has the pinouts marked on the board.
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
1helpful
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
