I have a Gateway VX1120 CRT monitor and the screen is kind of dark. I brightened it all the way using the adjustments on the OSD screen and it is still kind of dark. Any solutions out there besides buying another monitor? Thanks
SOURCE: 19 "lcd gateway monitor will not power on.
Is this a Gateway FPD1960 monitor? If so the power supply inside of it died. It is a common problem with these. I repair the Gateway FPD1960 monitor so if you want to trash it let me know. You can contact me at sure-power(at)nc.rr.com
SOURCE: OSD Lock Problem
OSD Lock / Unlock: Tasten + - > (plus, minus, rechts, also die mittleren 3 Tasten) gleichzeitig für 3 Sekunden drücken. OSD Lock / Unlock: keys + -> (plus, minus, right, so the average 3 buttons) simultaneously for 3 seconds.
SOURCE: gateway 900w monitor
the back light must be gone bad, need replacement, contact to sevice center
SOURCE: Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
SOURCE: monitor goes dark after a few seconds
it looks like the video driver needs to be chcked. can you try to go to the bios of your omputer by pressing f2 on boot and let it stay there for 5 minutes? if it still goes to a black screen, its either your video card or lcd thats having a problem. but if it doesnt goes to a black screen in bios, its just the video driver. go then to safe mode by pressing f8 on boot. then uninstall and reinstall the video driver. or run system restore. restore it back to a working date thts by clicking start, then click all programs, go to accessories, go to system tools, click system restore, choose an earlier date and hit next, follow the prompts,wait for the computer to restart and that should work!
Try using a I.O.gear V.G.A. splitter which works with 120 volts. It is a small box that you attach your output from the cpu into the splitter and you will have two amplified outputs. That if you wanted to you could run two monitors on it. I have a gateway ev910 and had trouble with a lack of brightness this boosted it right up. The unit sells for around $25.00 and uses V.G.A. hookups. You can also just try using a two way V.G.A. Y splitter. I did this and didn't hookup the second V.G.A. socket. For some reason this really brightened the crt monitor. Hope it works. Good Luck, Sincerely, Alan.
