Everything is set right on the clock except the day.I've tried everything I can but I can't get it right.Please help. The clock is a ACU-RITE 13036 -RX
You have to set the Year. Hold the time Set until the hours blink then push the time set button again and the minutes blink then push the time set button again and the year will blink. Change it to 09. Then push the time set button again and set the date.
I would try Crutchfield first. They have audio experts on hand and will sell you the correct kit. If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
First unplud everything except the monitor and keyboard from the system. This can help to narrow down the problem. If it boots after doing this then one by one plug everything back in until you find the problem device.
Also try leaving it on the Acer screen for a while to see if you eventually get an error code. You might even have to let it set there for 30 minutes or so.
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
There is a utility called Process Explorer on the Windows Sysinternals web site. It is very good at showing which processes are using a lot of memory. It may be helpful in determining what's causing the low memory problem. Process Explorer can be downloaded at this link: http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
If this solution is helpful please click a thumbs-up rating below.
Hold the "sel" button for 2 seconds, , "CLOCK H" comes up, then adjust with round silver knob. Use seek button if you need to change from CLOCK H to CLOCK M to change minutes.
