Question about Alpine ERE-G180 11-Band Car Equalizer
Alpine eq 3331 install
How to wire the eq. i have a eclipse deck with 3 outs front , rear & rear non fader.i have 6x9s to the front & rear with a 4 ch kicker amp & the rear non fader has the subs with a 2 ch punch 601.any help on how to wire in the alpine 3331 eq THANKS for any advice
Posted by jbtops on
rteemon
  • 578 Answers
USE THE FOR CH RUN ALL THE SPEAKER THE MEANS TWO RCA ONE FOR FRONT AND ONE FOR REAR INTO THE AMP AND NON-FADE REAR-FOR YOUR SUB --POWER FOR EQ--[POWER 'REMOTE AND GROUND]
Posted on Aug 07, 2009
Head unit connect
You will only be able to use this EQ on the front or the rear speakers. You will have to get another EQ if you think you need one. Usually, the front speakers of a car's audio system are the smallest and the rears are larger. You really do not want an EQ on the subs. If it was mine, I would hook the EQ between the head unit and the rear speakers. If you feel this does not sound right, you may need, but I doubt it very much, to get another EQ for the front speakers. Good Luck
Aug 18, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
I had some kicker 6x9 cs693 installed in my 2002 camry rear deck and when they returned the car the spearkers are not producing much sound or bass. I am using factory stereo and also the factory 6x9 on...
first check to see that the fader is not programmed to the front speakers fading it rear might solve your problem, second if your stereo has a 4 ohm load requirement at the output and your new speakers are 8 ohms this will cut the power output in half, your best bet is to get an amp if these do not solve the problem.
Feb 27, 2015 | Kicker Car Audio & Video
How to wire alpine 3331 preamp eq
What are you asking, I would repost with more info so somebody can help you.
Oct 19, 2014 | Alpine Audio Players & Recorders
Need the wiring diagram for a realistic eq booster model no. 12-1955
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
Apr 16, 2011 | Car Audio & Video
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
How to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
Jan 29, 2010 | Eclipse EA3422 Car Audio Amplifier
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Alpine ERE-G180 11-Band Car Equalizer Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
