Hi, I have a ilo tv 32 "hd with this problem, when I turn it on, the TV goes to the image with the logo of ilo, and then restarts and restarts and restarts, etc..
someone would know what is the problem and what is the solution.
please help me with this problem.
I hope your answer, thank you very much.
(excuse my English, I speak Spanish)
Excuse my English too. It sounds that the firmware to this TV has been corrupted by any way. A firmware update might be necessary. There is booting problem. If you wish to know more abut firmware update, check the site linked below. It has details to firmware update procedure to many brand TVs with illustrations. Beware, you must be sound in electronics to follow. http://electronicshelponline.blogspot.com/ Pull
up previous posts there, either by its left side bar, or view it in Timslide
option. The site is in English language, but have translation option, which can be pulled out from the right side of the display window.
The main power supply will be the first place to check. You should have at least the standby 5vdc, which is used for the main board, when the power switch is activated, the main board will send out the signal to turn on the main power supply sections to power up the rest of the set. Look for simple thing like blown fuse or bad capacitors. Learn about what bad capacitors can do. http://en.wikipedia.org/wiki/Capacitor_plague
I have the same problem with mine. Screen was gray but I had sound. Nothing I tried worked. I bought a new TV and the Ilo is sitting in the junk room till I find a solution or get the ambition to take it to a shop to get checked out.
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
