beleive it or not all pools are not created equal
you can have 2 different brand pools the same size and they will have different water capacity
in your case since you did not tell what model pool we will go the average route
15x48 is an average of about 4000gl
that translates to about 100 pounds of salt
most important is to get a salt test kit and a chlorine/ph test kit both for about 10 bucks each
start with 75 pounds salt throwing it right in the pool then pushing it around to help dissolve it like with a brush
you want 98% pure pool salt, not iodized salt best to get this from a pool store 40lbs for 8-10 dollars
remember not to let them sell you thiungs you do not need or give bad advice
once salt is in and partially disolved turn on filter only for 24 hours
now check salt level with kit
it is imparitive to have your salt level at as close to 3000ppm as you can
you can be as high as 4000ppm but remeber the higher it is the more salt taste you will have any lower than 2500 then it is hard to generate chlorine when needed
try to find some of my other posts dealing with cloudy water and green water and you will read more info on filtering which is a major factor
If you have more questions I am at
[email protected]
