Electrolux EWF1282 Front loader washer. Timer counts down on the clock but the machine doesn't operate. Makes a humming noise but the cycle won't start even though the clock is counting down. Have tried it on every wash setting.
SOURCE: I have a fridgidaire front loader washer that
Check the drain hose where it goes into the wall, make sure it's only 6 to 10 inches in the standpipe. I have seen this issue countless times.
http://www.appliancerepairlesson.com/
SOURCE: I cancelled the rinse cycle before it was finished
Hi If the door lock assembly is fine then the issue is with the
control board that is bad and should be replaced. Hope this helps...please post
back for further assistance. Daniel
SOURCE: Our washing machine starts up like it is going to
Hi from retired Englishman in SW France
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
The output from the timer to the motor has failed and so it seems that the timer program controller unit is faulty. You will need to confirm the failure of the output using a multimeter. Also of there is power to the motor, check if the motor is warm or hot . If so the capacitor to the motor can be a suspect. Also failure of the motor winding's or a mechanical jamming cannot be ruled out. check the free movement of the drive.
Testimonial: "thank you for your help. looks like i'll be busy tomorrow"
SOURCE: I have an LG front loader that gets stuck right
your pressure sensor is not detecting the water level change
