Koss DVP2161 Portable DVD Player without Screen Logo
Question about Koss DVP2161 Portable DVD Player without Screen
Koss 8.4 inch, Model No. KS5846-2
I just got this yesterday. It's charged and the movie plays, but it constantly stops and starts...jerks off, forward a bit, then on again. What can I do to fix this.
Posted by UFarm2 on
  • ralf55 Feb 19, 2008
    8.4 dvd player ks5846-2 screen does not display setup only sound
sm hanif
    Problem Solver:
  • 5 Answers
"it constantly stops and starts"while you are in the car(DVD"s fitted in your car)? If so, fit it with a shockproof like rubber.If the dvd is not fitted in a car then check the lens.
Posted on Oct 15, 2007
When playing a movie from a USB stick my 55 inch Blaupunkt tv stops after 2 hours and goes back to the start,very frustrating. Any ideas
The entire movie has not been recorded of the flash drive. There was not enough GB storage for the movie. Either use a flash drive with more capacity or record the movie on a DVD
My 2012 gmc terrain has done this twice. Remote started to cool, got in car turned and turned key, out foot in bread to put from park to drive and it jerked forward and killed when I hit the gas. Moved...
believe it or not it is the norm and is more annoying in the 4 cyl --havent had it stall thought their a slush trans personally hate them also will act like slipping when trying to pass excessive revving the 6cyl happens less and the higher revving usually doesnt happen but in traffic may get the jerking also but GM constant states normal
How come my 8 inch tablet isn't charging
charging cord is cooked, or from jerking sideways sometimes the interior of the charge port can get damaged. try a different charge cord
1helpful
How to stop buffering
  • 1 Allow the movie to load completely, or at least halfway, before you start to watch it to stop video buffering.
  • 2 Start the movie and then hit stop until the movie has fully or halfway loaded. As the movie is loading, you should see a yellow or gray line. The line you see will get longer as it loads.
  • 3 Close all windows that you don't need. Having too many windows open will slow the loading process.
  • 4 Resume play once the movie is at least halfway loaded or fully loaded. By this time, you should be able to enjoy the movie without the video buffering or constant starting and stopping.
2answers
CAN"T PLAY MOVIES FROM MY USB ON 32 inch HISENSE TV. What format should the movies be in? Presently they are in avi
i have a 32inch hisense led tv i watch movie using usb but it stop and back to the begining when the movie is over 2hours.. hope you can help me .
Magnavox portable DVD player Model MPD 102 will not play a movie till the end. COnstantly stopping/freezing.
My son's Magnavox Portable DVD does not seem to be functioning properly....It won't turn on, and when I plug it in, as if I was going to charge it, it blinks orange then green. So, it seems like there is a problem with it. Anyone experience the same problem?
1helpful
KOSS HOME THEATRE
Salutations robn7499,
There are a few things that may cause this to happen. First I would check your connections for your center channel speaker. in movies with 5.1 surround sound almost all the vocal tracks come out of the center channel.
Otherwise there maybe an issue with the volume levels for the center channel as well, these can normally be adjusted through the setup of your home theater system.
I hope this helps.
Jon
Go Ahead. Use Us.
Movies will start...then stop
Dori,
Get a DVD Laser Lens cleaner kit with a disc and fluid. Run the kits per instructions, This may help. If it doesnt your laser may need a mechanical or Electronic adjustment.
Top Koss Televison & Video Experts
Marvin
Marvin
W.L.
Simon Atkinson
Simon Atkinson
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
