I used this brand new mower twice with no problems. Then mowed a ditched hill aggressively(?), and now the mower stalls while simply cutting flat grass. If I take my foot off the hydrostatic forward pedal, it seems to recover. But repeats the stall a few feet later. The Reverse Operating System also doesn't seem to work, as I can cut in reverse without altering the key in the ignition.
SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
SOURCE: I have a craftsman electric key start lawn mower.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
SOURCE: A row of uncut grass left between blaces when mowing
Mowing too fast for the blade speed. Use higher engine speed or lower gear.
One or both blades too short?
SOURCE: Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
