Question about Canon S200 InkJet Printer
Black ink not printing
I changed inks and only color ink appeared and the blank ink never print anymore...do i need to change my printer? is my printer already out of order? what i must do to let the black ink run properly?
Posted by yipyipsun on
  • 2 more comments
  • Anonymous Jan 09, 2008
    y have the same problem
  • Anonymous Aug 15, 2008
    Exactly the same problem
  • CANONCURE Dec 15, 2008
    I have exactly the same problem - has anyone found a solution? - I really need to get is sorted out -
    Thanks
  • Anonymous Mar 22, 2009
    I have the same problem, please help!
Anonymous
  • 31 Answers
If the black never print anymore but that is new clean the printer head.or go on start programs click printer or faxes, installed will appear right click on the printer name proterties go on service then then box will appear u can their the word allign cartrigde an clean.
Posted on Jun 20, 2009
Epson stylus dx6000 only copy in color mode
Check the printers settings. It could be that it is set up incorrectly or you may be out of ink and it only appears to print from your computer because it can use all colors to make it appear black ink is used. Usually when color ink is used to create black print, it isn't a Black Black but with a bit of brownish hue. Try changing setting to USE BLACK ONLY and then see what happens. ALSO TRY my solution vice a versa.
Good luck
Mar 15, 2014 | Office Equipment & Supplies
Changed new ink but when i print, the pages come out blank with no ink. Printing motion takes place but some how the ink done not reach the paper.
I had the same problem with my DCP 165.It simply wouldnt print.The paper was coming out but it was Blank.I had changed all the cartridges so there was no obvious issue with the ink.Then I printed a test page.It printed all the colour blocks except the black.Then i found out from Brother website that it was a problem with cleaning and after seeral cleaning cycles the printer worked fine. STEPS 1>ink management 2>Cleaning 3>Black or colour 4>OK Repeat the above process several times and try printing after that...Hope it works
Sep 15, 2010 | Brother DCP 165C Compact Color Inkjet...
Just replaced my black ink but printed page comes out blank
Change your print preferences to black and white as a work-around until you get color.
Aug 10, 2009 | HP PhotoSmart 7660 InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Printer dont print without one of color ink
u should use all cartrige for printing with your printer
Apr 24, 2009 | Office Equipment & Supplies
Black ink only
Print using pigment black ink only (Windows) Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Why can't I print using only black ink?
If any cartridge is empty, the printer will not print at all. No, there is no way around this.
Feb 20, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Canon S200 InkJet Printer Logo
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
