Locating Your Model NumberThe Model number is eleven characters long and is printed on the left side of the Product Identification Label. Characters can include numbers, letters or hyphens.
Troy-Bilthttps://support.troybilt.com > article
RECENT PRODUCTION tiller models, machines manufactured since 2001, will have a model and serial number sticker normally located on the tine hood of the machine.
Trying to figure out how old my Whirlpool washer is Locate your machine's nameplate, which contains both the model and serial numbers. On top-loading Whirlpool washing machines, open the lid and look for the tag at the top rear of the tub. On front-loading washers, the tag is usually inside the door or near the bottom of the left or right side of the cabinet. If the tag is not in one of those places, pull the machine away from the wall and check the rear. Record the serial number with a pencil and paper or take a photograph. Be sure to record the serial number, not the model number. Decode the serial number at an online source like Appliance Cafe or Appliance 411 (links in Resources). Whirlpool serial numbers include a code in the second character for the year the product was built. Before 1990, the character was a number; from 1990 to 2010 the character was a letter. The number sequence started over in 2011.
I see that you are inquiring the location of the model number on your Frigidaire washer. The serial tag, which lists your model number, is typically located on the upper front, as you open the door on a front load washer. If you have a top load washer, you can find the serial tag inside the lid, on the right side. I hope this information helps to some degree. If I can be of further assistance, please feel free to reconnect.
On the Maytag Gemini Series Double Electric Oven, the Model and Serial number is located on a flip-up metal plate/tag which is located on the upper left side/rear of the of the control panel. There is no need to move the stove away from the wall. Simply place your fingers over the top left edge of the control panel and flip the metal plate/tag up from a point just left of the control panel's center and flip it to the left (it's hinged on a screw to the far left of the flip-up plate/tag).
It will be stamped on a metal tag located either behind the top control panel, under the lid, or on the lower part of the machine on either side or at the bottom. The metal tag will have the serial number, model, as well as the year it was manufactured.
its pretty that you get the service tag or the model number of the system. not the serial number of the monitor.
if not in the cover of the system , maybe you should open the system and find model number in the motherboard. Like dell product ..there is a service tag sticker in the back of the system.
