I have a benq w100, it's pretty old but still works pretty well. During a recent trip something has broken and even if the projector seems to be working, when it starts there's a loud noise like a fan was hitting something and after a minute more or less it stops and the temperature led goes on. I've opened it and the 2 fans in the front seem to be ok, the noise seems to come from the area below the board but i can't see or access that area since none of the screws seem to enable me to remove the whole board. Anybody knows if there's a third fan apart from the 2 in the front or what can be the cause thanks!
SOURCE: BenQ PE7700
Check if the unit has a Filter Timer ? If it does have one - check the hours on it and reset it.
If the problem still occurs or there is no filter timer in the Menu - check that all your fans are running.
Hope this is of help
Goodluck,
Please don't forget to rate the solution.
SOURCE: temp and lamp led turn on after 1 Minute
The fan has again got burnt out. Try replacing with the fan of the Benq Brand or a compatible one as depicted in the manual or contact:
Headquarters
16 Jihu Road, Neihu,
Taipei 114, Taiwan
Tel: +886-2-2658-8880
Fax: +886-2-2797-9288 or check up the address from the net regarding your country's support or Authorized representatives close to you and get the details mailed back.................sodeep
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
