Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture is wiggling. Like waves.
Just bought a Sony Trinitron flat screen tv. Model KV-36XBR450. The guy we bought it from said he had it for five years and worked perfectly. My husband tested it out for five minutes and it was fine. Bring it home and withing 30 minutes, the picture started wiggling. It does this off and on. Sometimes throughout the picture and sometimes only part of it , for example top, middle, or bottom. It's making me dizzy!!! What could be causing this? We tried to see if it was the connection to our digital box but when we connected it directly to the cable line, it still continued to do this.Other tvs in our house that are connected to cable is not having this problem. Please help!!!
Posted by agnes_medina on
Anonymous
    Sergeant:
    Champion:
  • 318 Answers
The power supply has variations meaning your supply is not constant, it is not giving the same outputs voltages.
plse check the following
capacitors which have changed values
semi conductors which are leaking.
thanks for trusting fixya.
Posted on Feb 01, 2010
Sony trinitron tv
Hello!I bought 12 years ago a SONY TV KV-28FX60D with out any technical issue so far.The last couple of days I powered on and after five minutes it starts showing only half of the screen, losing the bottom half of the picture. what do you think it might be. Can you suggest a part to be replaced and if it is worth fixing, cost wise? Thanks KONSTANTINOS
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
2answers
Does the sony KV-30HS420 TV used a lamp..if yes where to lacate it
the KV-30HS420 model is a CRT based set and thus has no "lamp". What is hte proble with the set?
Dan
Kv-36xbr450 picture freezes or wiggles
Check the cables going in and out of the tcon board if that doesn't fix it replace that board
1helpful
KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
SONY KV-32FX20U
I suspect you crt tube is going and is most likely not worth fixing
There are things you could do a tv service shop could rejuve your picture tube and adjust your screen voltage.
sometimes that does not work
I would start looking for another tv
thanks doctor video
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Blank screen on sony trinitron tv
The problem with this model is the large parts due to poor wave soldering. Locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down.
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
