Question about Yamata FY14U4AD
Free download of singer overlocker manual
Can't thread correctly. Thread breaks maybe because not putting material in correct place. HELP! machine is a copy of singer yamata FY14u
Posted by surriea2008 on
Anonymous
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Posted on Oct 20, 2009
Singer 9960 won't sew. Thread bunch up underneath material and thread breaks
Be sure to install a brand new needle and that it is facing the correct direction.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Set the tgp tension to the midway point.
Verify the bobbin is loaded and thread correctly.
AVOID old or bargain bin threads.
Mar 22, 2018 | Singer Sewing Machines
Janome 8200DG overlocker feeds materials and cuts but not sewing [email protected]
Could be because it is not threaded correctly. Remove all the threads from the machine, and then step-by-step follow the instructions in the manual. It may help to install new needles. ALWAYS RAISE the presser foot when threading. Be sure to thread each thread IN THE CORRECT ORDER or your machine will never run properly.
It also helps to use separate thread colors so you can determine which thread is doing what and which one is not working properly.
May 29, 2017 | Janome Sewing Machines
How do I thread my overlocker
If thread is breaking, it usually means it is threaded incorrectly--either you have missed a thread guide or have it looped somewhere it shouldn't be. The tension could also be too tight on that one thread.
RAISE the presser foot BEFORE threading!
Be sure you are threading each thread in the ORDER described in the owner's manual. Most machines are threaded in this order: 2nd thread from the right (upper looper), last thread on right (lower looper (this thread must cross over the top of the upper looper in the final step!!!), then the needles--but you must check your machine's manual for the correct order!
Confirm with your owner's manual that you are threading all the guides. If you miss one of the thread guides, your machine will most likely not operate.
Also, if you break a thread, it is strongly recommended that you remove ALL the threads and start over from the beginning. Sergers can be very finicky!
This video may help, although your machine may thread differently:
How to Thread Serger Overlock Machine
Oct 28, 2015 | Sewing Machines
Bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1295_3270.pdf
Dec 21, 2012 | Singer 3343 Mechanical Sewing Machine
Singer Inspiration 4220/4228--I can't get a good stitch on lightweight material. Can you help?
in your manual on page 6 it has a chart for needle and thread combinations for fine or light materials. For your convenience I have included the download of the manual here. (see pdf page 16)
http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf
When using lighter fabrics it is very important that you use the right thread and needle combo. Start with the correct needle and thread for your application then adjust the tension to match.
Good luck
Jul 27, 2012 | Singer Sewing Machines
Singer futura XL400 thread breaking
Unthread the machine and start from scratch. After rethreading make sure your spool of thread has free play at the reel (not caught on anything) then check the thread tension make sure it's not too tight. Also check the bobbin is in place correctly and the bobbin has been wound correctly not too tight. If it is still happening it may be an adjustment to be done by a tech? Also try different threat, faulty thread can do that as well.
Mar 11, 2012 | Singer Sewing Machines
How do I tighten the tension. My bottom thread is
To increase the tension,turn the dial one number up until the thread length/tension is correct for your needs. You may download the manual free and info on adjustments is on page 28. Happy Sewing!       http://www.sewingmachinesplus.com/media/products/singer/2932/Manual_2932.pdf
              # 0             0
Jul 24, 2011 | Singer 2932 Mechanical Sewing Machine
Bobbin thread does not loop up when threading machine. Then the needle thread get wraped around the inside the bobbin sewing the material to the machine
There are so many thing you need to re-check.
First clean out the bobbin area to be sure there aren't any thread tangles still there.
Open the manual and start from the beginning with threading the machine with the presser foot lever UP - always.
Read the instructions and do not rely solely on the pictures as we all sometimes rush to do (I am just as guilty as the next person to do this).
Make sure the bobbin thread is feeding from the bobbin case in the correct direction.
Hold onto the end of the top thread (after needle has been threaded) and lower then raise the needle to catch and bring up the bobbin thread.
Place the fabric under the presser foot and as you hold onto the ends of the top and bobbin thread, hand walk the first stitch, then use the power pedal.
If you need a manual, you can download (free) from Singer - http://www.singerco.com/accessories/manuals.html
Mar 25, 2010 | Singer 8280 Mechanical Sewing Machine
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Needle will not go down and pick up bobbin thread
Check for a thread jam in the bobbincase. Lower looping is most commonly caused by a lack of top tension. Raise the presserfoot and rethread themachine again. Once threaded put down the presserfoot and pull the thread through the needle. if it pulls through easily it is still not threaded correctly. When threaded correctly the needle should bend but not break when you pull the thread through. good luck.
Jan 29, 2008 | Singer 1507
Yamata FY14U4AD Logo
Top Yamata Sewing Machines Experts
Michael Thomas
Michael Thomas
ADMIN Canada
ADMIN Canada
Ruth summersides
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
