Question about Canon Video Cameras
Vcr turns on and plays but the picture lines on screen
Trying to play my home 8mm movies on camcorder. Camera works in vcr mode but the picture on the tv and on camera viewfinder have horizontal lines that move quickly. Therefore cannot copy movie because they will have horizontal linesHow can I get rid of these lines?
  • 4,234 Answers
The camcorder has a problem in that the heads are probably not locked in frequency. This is not an uncommon problem with older units. There are some capacitors in the circuit that controls the head speed that are defective. This allows drift in the speed of turning which will result in an uneven signal. This is not a trivial repair but the parts cost is minimal (less than $10). Look for a repair shop that works on camcorders and get an estimate. When I get these units the total cost usually runs around $150 for parts and labor. Realize that even with experience, this is a 3-4 hour job.
Dan
Posted on Mar 25, 2009
6ya staff
SOURCE:
The LCD is blue and won't play back . We have cleaned it. Camera mode works when recording. Just no playback picture in VCR mode. ...
you most likely has a bad screen, if you can, play back your video into a VCR, dvd burner or televisino with rca type inputs, this will at least let you save your movies.
Mar 18, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
I have a GE CG818A Camcorder, when I play it it only plays black and white. Was wondering if there is a used Sony or any camcorder that would play my Video8 P6-120MP tape, in color.
I have the exact same camera and same exact same problem. Any analog Video8 or Hi-8 camcorder or VCR will play these tapes.
By using the same cassettes as Hi8, many (NOT ALL) Digital8 (produced by Sony exclusively) camcorders are able to play analog Video8/Hi8 recordings, preserving compatibility with already recorded analog tapes.
you can connect Digital8 camcorders to your computer to download your movies for editing or Internet use.
As of 2008, Digital8 camcorders have been removed from the equipment offered by Sony.
Sep 29, 2010 | Sony 8mm Stantard Grade 120 Minute...
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
MY SANYO CAMERA MODEL 8MM VM-d66P SHOWS A WHITE
IF YOU CANT GET THIS FIXED CAN I BUY IT FROM YOU AS I NEED A 8MM CAMERA TO CONVERT MY TAPES TO DVD AS MY OLD 8MM CAMCORDER WONT PLAY.OR DOES ANYONE HAVE ONE I COULD BUY CHEAP OR BORROW...IN MELBOURNE AUSTRALIA...CHEERS JB
Jan 09, 2010 | Sanyo VM-D6 Camcorder
Can't play back my JVC Video Camera on TV screen
it is possible that the movie format on your camcorder is not one that is recognised by your TV
Apr 20, 2017 | RCA CC6363 Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
I can't get a picture on my television when I have my Viewcam connected into my VCR.
Make sure the Viewcam is connected (cable supplied) to an A/V input on your VCR. Set your VCR to the Line In or Auxiliary mode. Turn the Viewcam to Camera or VCR mode if playing back tape. Viewcam image should appear, if not call 1-BE-SHARP.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
89 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
