Master
- Posted on Mar 25, 2009
Re: Ihave a sony KP53S75 TV there was apower surge and...
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the
television. This can sometimes be resolved by simply following the
steps below to reset the television.
- Turn off the television. IMPORTANT: For
a projection television that uses an internal lamp, wait 5 minutes
after turning off the television to allow the lamp to cool before
continuing with the following steps.
- Unplug the television power cord from the electrical outlet.
- Let the television remain without power for 60 seconds.
- Plug the power cord back into the electrical outlet. NOTE: If
the television is plugged into a power strip or surge protector, remove
it from the power strip or surge protector and plug it directly into
the wall outlet. If the issue is resolved, the problem is with the
power strip or surge protector and not the television.
Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Light blinks 4x. did the rset test. still not working. How much will it cost to fix?
Hi, is this TV plugged into a surge protector at this time??
