Question about Gaggia Evolution Espresso Machine
Gaggia Evolution Espresso won't heat up
Hi, my machine won't heat up when I switch it on. The power light comes on and the pump still works, but the water isn't hot. Any advice appreciated.
  • Anonymous Mar 25, 2014
    Heat light won't come on
    Novelist:
  • 137 Answers
1 heating element defect(needs replacement)
2 security termistat, (replacement or reset)
Posted on Mar 27, 2009
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
Apr 11, 2010 | Gaggia Evolution Espresso Machine
The pump does not run water through the filter head. It makes a noise and pumps the hot water back into the water tank
Almost certainly due to the reverse side of the brewhead being scaled up. The evolution has a recess on the reverse of the head that block causing no water to come out. Remove the head and clean it off.
Dec 31, 2009 | Gaggia Evolution Espresso Machine
My gaggia evolution leaks water while making coffee .It appears to be coming from inside the machine and leaks everywhere.I have disassembled the machine but i still can 't see where the water is coming...
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
Oct 22, 2009 | Gaggia Evolution Espresso Machine
When the hot water switch is pressed, no water is pumped.
group head is blocked. remove centre screw from the group head remove spring and valve, clean and re assemble.
Sep 20, 2009 | Gaggia Evolution Espresso Machine
Steaming problems
Have you tried descaling the machine?
Mar 14, 2009 | Gaggia Evolution Espresso Machine
Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Feb 27, 2009 | Gaggia Evolution Espresso Machine
Pump problem on a Gaggia Espresso Evolution
You need a bellows pump or similar, when you start the pump you need to set the pump to the water inlet and press in the water with force.
Jul 09, 2008 | Gaggia Evolution Espresso Machine
Gaggia Evolution Espresso Machine Logo
270 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
