Protron PLTV-4250 42 in. LCD Television Logo
Anonymous Posted on Jun 27, 2013
Protron pltv 4250 keeps shuting off
I have a Protron PLTV-4250 that keeps shutting off. I push power and the green light comes on and turns right back to red and cuts off. Had this issue six months ago but it just started working and has been working fine up until now. Help please?!
Level 3:
Top Expert:
  • Protron Master 76,851 Answers
  • Posted on Jun 27, 2013
Protron Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987150
Points
237762
Main digital board should be checked. In most case, might need replacement. Contact any service technician.
5 Related Answers
A
Anonymous
  • Posted on Aug 26, 2008
SOURCE: My PROTRON LCD PLTV 32 IS BLACK & DEAD
I had a pwer supply for my Protron 32 inch TV that was not working. I bought the one on ebay and it stopped working after only three weeks. Ultimately I found a guy who could fix my original power supply for a reasonable price. It been working for a year now with no problems. I wish I would have tried him first!!!! If anyone is interested his email is [email protected].
Anonymous
  • Posted on Jun 01, 2009
SOURCE: I have broken Protron PLTV-4250 42 in. LCD TV.
I have one but it will not stay on let me know [email protected]
Anonymous
  • Posted on Jun 04, 2009
SOURCE: protron lcd tv getting no power
I have the same problem. I am told that I need a new power supply (adaptor) but from what I am reading on the Net, they are very rare and TV repairman told me he cannot find the part. I heard that Protron is out of business.
Anonymous
  • 6 Answers
  • Posted on Aug 31, 2009
SOURCE: No power to my Protron PLTV 3250. What can I do
My Protron PLTV - 3250 just went out yesterday. By this I mean it turned on and went out in a few minutes. I left it off and today it completely died. I opened it up because I always think I can repair things. So what I found is a burn mark on the curcuit board of the power supply which is located inside the tv. On the other side of the burn mark is a (zener diode), this diode is burned out and therefore the power supply is not working. I am going to Radio Shack tomorrow Monday Aug. 31, 2009. The diode is very tiny but should be easy to replace with a sauder gun because this diode has place holders to hold the tiny diode in. If this does not work at the top of this page is a link that says power supplies for your tv for sale. I am going to check it out. Anyway just so you all who know about computers= the tv power supply is similar to the power supply on a computer. Just like a computer power supply comes in a case that you install into your computer and then you just connect the connectors to your motherboard and drives. Well in the tv the power supply is stand alone also, you can disconnect the wire connections in the tv and replace the power supply. If you notice the power cable to your tv is the same as a computer power cable, so the power supply in the tv is much the same as a computer power supply. I hope this helps you.
Anonymous
  • Posted on Sep 20, 2009
SOURCE: PROTRON PLTV 3750 POWER SUPPLY BOARD REPAIR
if you look at the power supply board you will see an aluminum plate remove the four screws and 9 out of 10 times it is a diode on the board that has gone out. go to radio shack and for 83 cents you can buy one the same size. I personally have tried all the diodes that they sell and all of them that are the same size physically will work. I have three of these tv's and all of them were the same problem. I replaced the diode in each with one of each of the same physical size sold at radioshack and they have been working like new since.
How do i fix protron
Here is a great link for the manual:
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=21#manual
Try page 21 through 25. There is no "factory restore" function, but you can adjust the hue and colors.
Hope this helps. PROTRON PLTV 4250 User Manual Using The Remote Control
Protron Pltv-4250 42 Widescreen HDTV LCD TV NO SOUND
Try disconnecting from power for 30 mins and connecting back
2answers
HDMI connection
A downloadable copy of the manual for a Protron PLTV-4250 is available here.
I went through it to check up on your concern. It was mention in page 34.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Protron > PLTV-4250
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Protron PLTV-26 gets power but nothing else. No
i have a protron lcd menu light keeps flashing but tv wont come on any help would be appreciated.
1helpful
No video on my Protron PLTV 4250
check the video with a flashlight against the screen, if present the backlight inverter has failed.
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
