I had an old T60 WindowsXP. today I reinstalled with Windows7. however it cannot connect to extended display now- TV/projector. i have tried to press windows+P or Fn+F7 but dont work at all. in control panel it can only detect one display- also at the same time i have the HDMI cable on TV and laptop. who can help me to answer this? or do I need ATI graphics driver X1300? tried to download some but dont work. no clue now. thanks
SOURCE: cannot display image on a proector using Lenovo laptop
Sounds like an extended desktop. have you tried dragging an open window (ie. internet explorer webpage) to the top, right, bottom, AND left? When you get to one of the edges, move it like you are moving it off and it should move to the other screen. You can change your setting to 'duplicate' your desktop in your video settings.
SOURCE: CONNECTING ACER TO THE TV
Hi I have an Acer Aspire 4920. It's a good laptop and have been using it for about 2 weeks now. One issue I have is that the VGA connector on the laptop has no screw holes which means when your try to screw the VGA plug to the socket via the thumb screws..you can't!! This isn't a big problem but its sub standard.
As far as connecting it to the TV is concerned. The laptop should have a yellows S VIDEO out din socket on the left hand side near the buillt in NETWORK and MODEM Line ports. You need to connect a SVIDEO cable from here to the TV's SVIDEO or SCART(using a suitable SVideo to Scart). Then make sure the TV is set on the correct SVIDEO input. Now reboot the laptop. The [FN] + [F5] only works if you are using the VGA output to a LCD or Monitor/Projector. Once back into windows desktop you need to go into the properties of the graphics card and activate it through the menu under one of the tabs.
Hope this helps.
dab
SOURCE: IBM Lenovo T60 connection to Samsumg 50'' TV using CGA cable
Try just pressing "Fn" and "F7" keys until the output switches to your TV.
SOURCE: Problems with Lenovo 3000N200 0769-EAG tv-out
My friend, the easiest and by far the best way I have seen is to set the
advance timings on your laptop just right and use a vga to scart cable.
Restart your Laptop to recognize again your TV on the system.
SOURCE: Lenovo T60 interfacing with Vizio HDTV using RGB cable
SN:V6-72866 a 3rd of screen is blairing and turning white
