Is this an easy fix?
SOURCE: door handle broken (rear left)
did you just break the handle or did you break it off from inside the door also? If it is only from the outside that is a much easier fix. Let me know what the issue is and I will try to help you as easy as possible.
SOURCE: Driver's door handle will not open the door
Take it to the buick dealer. As the daughter of a mechanic, it was a call I didn't want to make! The dealer installed two handles for me and painted them to match for under $100.00. Well worth the trip.
SOURCE: How do you replce broken door handle?
This is a problem that you should be able to fix. With the interior door panel there are 3 screws. 2 in the arm rest and 1 on the door handle(opener), take those out. There is a C-clip on the window crank that needs to be removed. They make a cheap little tool to remove those but I've heard people using a shop rag and removing the c clip. To remove it, turn crank to around 9 oclock then slide the tool or rag behind the crank also coming from 9 oclock. Any position will work, my point being the tool must slide in from behind the crank handle. Use a flat head screwdriver to gently pry the edges of the door panel away. There are some little clips that pop loose. It's okay if some break you can buy more. After that you will slide the door handle (opener) forward a little to pop out. Twist and turn the panel to get it over the door handle. There are 2 bolts that hold the handle on from the inside. They are 10 mm. You can reach the most forward one pretty easy but the back one is taken out through a hole in the metal door panel. Mine had a sticker over the hole with a big yellow dot on it. After that it takes some pretty good force to get the handle out of the hole. Don't be afraid to push on it. When it pops out take some wire cutters and cut the little plastic clip that holds the metal rod to the handle. The lock twists out of the hole. Now this is when you need 3 hands. Hold the new handle close to the opening and twist the lock into position. Don't attach the metal rod yet. Now actually put your key in the lock. This helps you hold the lock in the correct position while inserting the handle. Put the top of the handle in first and then the bottom should snap in next. Now from the inside, reach up and slide metal rod in the hole and rotate the plastic clip to secure it. Now the hardest thing is getting that back bolt in. It helps again to leave the key in the lock and rotate it so the bolt can secure the locking mechanism to the handle. Put the front bolt in reinstall the interior door panel and you should be in business. Good Luck
SOURCE: side door handles are broken. rear door handle is
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
