Question about Health & Beauty
When does the batteries need replacement?
The shaver jus went dead. When does the batteries need replacement? Is ther no warning light that suggest battery nees replacement? Or does it just go dead without warning? where do I find a battery replacement?
Posted by Veronica Badenhorst on
Bill Boyd
    Top Expert:
  • Health & Beauty Master
  • 53,814 Answers
The shaver will slow down as the batteries discharge. To suddenly stop suggests either loose batteries or faulty switch. There should be a charging cradle for the shaver to keep it working but if you need batteries then open the battery cover and replace with the same batteries.
Posted on Jun 26, 2013
Testimonial: "My husband always charge it after shaving(in the charging cradle provided), it didn't slow down or something, it just stopped working and isn't charging"
  • Bill Boyd Aug 13, 2014
    check for loose batteries. replace the batteries
5 Related Answers
mark7tenor
  • 5 Answers
SOURCE: battery replacement
The batteries are just 2 rechargeable Ni-Cd AA's, soldered together at one end to form a connection. I popped in two regular AA batteries, formed a connection between them, and it started spinning again!
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Posted on Dec 31, 2007
Anonymous
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
Anonymous
SOURCE: How to replace battery pack for a Norelco 6885xl electric shaver
The battery pack is soldered to the shaver's circuit board. Yes, it's a poor design in building something that people can't readily service unless they have a soldering gun, ******, and wick, plus patience. However, there are plenty complaints online already, and my shaver won't get fixed by b-tching some more.
There are 2 choices for replacement:
1. Bring or mail it to a service center to have the batteries replaced. The fee usually runs $29.99-$39.99, which includes the battery, parts, labor, lubrating your motor, cleaning the interior, cleaning/stripping the cutters, heads, and trimmer, plus return shipping.
2. To save yourself $26-33 bucks, make sure you know how to solder and have the equipment described above. you can find single NiCad AA with solder tab for $3ea or a pair for about $7.95+. Table the batteries together, solder a single tab across +/- on one side, and solder the others onto their respective tabs in your shaver.
For me, I'd love nothing than to hobby around and do it myself, but with 3 kids, a full-time, job, Wii, and other hobbies, it's easiest to just send it out... some services will guarantee to have it done within 2 days of receipt. You'll just have a lil beard to test it out when you get it back. :-)
Posted on Oct 16, 2008
Ron_Ray
Ron_Ray
  • 13 Answers
SOURCE: Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
Posted on Mar 28, 2009
Anonymous
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
My shaver does not work even when i plug in the cord. The charger light comes on but I do not know if it is charging. i have opened the back and saw the battery contacts corroded. Is the battery dead?
Model 6616X is a rechargeable shaver only. It is not designed to run directly from the cord. Probably, the battery is dead and needs to be replaced. You will find the correct bttery at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Aug 28, 2011 | Norelco 6615 X Electric Shaver
I have a norelco model 6701x that will not charge - the charger is good as it works on another shaver just fine. What would you suggest - have always been able to coax it into charging, or indicating...
Most likely, the batteries are dead and need replacing. You will find the correct batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To open shaver, remove flip up back cover then remove screws unserneath. At the page linked above, view helpful installation videos by scrolling down the page
Aug 11, 2011 | Norelco Health & Beauty
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
Unit does not take charge. sits on charger normal amount of time green light lit but no power at switch.
Most likely, the battery is dead and needs replaced. You will find the correct battery type at shaveroutlet.com. See link below
To replace, start by removing the lotion packet cover on the back. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 23, 2011 | Norelco Advantage 6705 X Electric Shaver
PROBLEM: WILL NOT TAKE A CHARGE. DEAD BATTERIES (?) - WOULD APPRECIATE PROCEEDURE NEEDED TO REPLACE BATTERY(S) FOR NORELCO ELECTRIC SHAVER MODEL 5821XL. SHAVER IS SEVERAL+ YRS. OLD AND IN EXCELLENT...
Dead batteries will cause the shaver not to charge. Batteries for model 5821XL can be found at shaveroutlet.com. See link below
To change, remove two screws on back and remove back cover. Remove plastic clip that is in the way of removing batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 31, 2010 | Norelco Reflex 5821 XL Electric Shaver
I have a philishave 905 and the original batteries were 600mAh 1.2V Ni-Cd. Once (6 years ago) they were replaced with 700mAh Ni-Cd without any problem. Recently I had the batteries replaced again in a...
Hi!
Warning ! NiCd and NiMh are two different technologies that require different type of charger !
Never replace NiCd with NiMh because a charger designed to charge only NiCd won't be able to detect end of charge of NiMh.
There is a risk of overheating and destruction of batteries and worse, destruction of the appliance !
(At the opposite, a charger that can charge NiMh can charge NiCd))
Regards,
Steve
Nov 25, 2010 | Philips Health & Beauty
How I change the battery and what is the cost of a battery.
If the shaver still works but just will not hold a charge as long as it should, you can fix this by replacing the batteries. If the shaver is dead and will not run and the green charging light no longer illuminates when you plug it in, you will need to change the whole circuit board.
You will find the batteries and the circuit board with batteries at shaveroutlet.com. You can order which you require by viewing the links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-printed-circuit-board-with-batteries-p-106.html
To open the shaver, you will need to pry out the two round plastic screw covers on the bottom then remove the screws underneath. You can then remove the outer case by sliding it down and off of the shaver bode. Then remover the black plastic cover inside to access the circuit board and batteris.
If replacing the entire circuit board, you will simply lift it out and replace. If just replacing the batteries, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 05, 2010 | Braun Flex Integral 6520 Electric Shaver
It is dead no power what can i do
Hi,I believe your shaver is a battery powered model..
If this is the case your Rechargeable batteries (built in) could have been dead..and needs to be replaced.But before taking it to a repair shop ,Whether electric or battery operated model please make sure you check the power cord as well,because sometimes one of the lead cracks at the point that it attaches to shaver,which the power cord needs to be replaced.
If you wish you can describe the problem more details than I may suggest something else.
Regards.
May 15, 2010 | Braun 360° Complete Electric Shaver
I have a Norelco 5822 XL cordless electric shaver. Suddenly it went dead and wouldn't take a charge. I took it to Batteries plus where the salesman said the batteries were completely dead. He changed the...
If the old batteries were corroded, that may have damaged the circuit board. If the batteries were getting hot before the shaver died, the heat may also have damaged the circuit board. It is also very possible that the salesperson did not do a good job installing them as they are not trained in replacing batteries in shavers.
For expert shaver battery installation, you can contact shaveroutlet.com
May 07, 2010 | Norelco Cool Skin 7775X Electric Shaver
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
Health & Beauty Logo
1,534 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
