Question about Pioneer AVIC-D3 Car DVD Player
Getting the map to track up instead of heading
Is there an adjustment that i can make to the nav system in my wifes car that will show the map tracking up, instead of her current heading. She finds this confusing and complicated to see quickly where she is and which direction she will be truning. My garmin allows me to set it up this way but i cant figure it out for the Pioneer.
Posted by todd_kulzer on
  • todd_kulzer Apr 20, 2009
    Thank you. I will try this.
Anonymous
Usually you can touch the red compass that points to north and it will change between heading up and north up. sounds like she has it set to north up.
Posted on Apr 20, 2009
How do I get the display to show my drive direction to be straight ahead, not 'NORTH' as being straight ahead?
In the navigation options menu, select Map Options and then Map Mode. Select Head Up, 2D or Head Up, 3D as desired.
Feb 06, 2015 | GPS
Navigation system and Acuralink
It sounds like your antenna is shielded. Some windshields have a tinting made with copper or other metals in them. Perhaps the windshield is blocking the signal.
Nov 25, 2013 | 2006 Acura RL Sedan
How can I use the evesham N20UK? Do I have to slot any SD Card before it work? There is no SD Card in the slot. Do I need an external SOFTWARE VERSION:G.0704191030M01, and how much is the cost? C.B.Seth....
THE MAPS SHOULD BE BUILT IN (AA MAPS)
Here is a review you might like to read...
I got the Nav-Cam because of the AA link. This was a mistake (are you listening, AA?). Here are my big moans (I have many more, but let them pass).
(1)I had to paint the shiny silver aerial matt black to stop horrible windscreen reflections. (2) Most times I start it up it jams and I have to press reset with a paper clip. (3) It takes silly routes through the centre of towns along the route instead of trying to avoid them. (4) It is s-l-o-w, and frequently misses the junction I'm supposed to turn at. (5) The touch screen is hopeless and only works reliably with the rubber end of a pencil. Trying to scroll using a fingertip is hopeless. (6) My house and street (built in 2000) are not on the 2007 map. (7) The Europe maps are a disaster, particularly in Spain, where it can't tell a dirt track from an ordinary road, and frequently therefore sends me offroad. (8) The journey timings, especially in France, are hopelessly optimistic (about 70% of what they should be). (9) Map updates? What map updates? Since many local road numbers have been changed recently in France and Spain, this means the directions it gives are worse than useless.
Conclusion: A complete waste of money. If you want a Sat Nav, then do yourself a favour: buy *anything* but this. Better still, buy a map.
Please rate my help++++Thanks for using Fixya
Aug 13, 2010 | Evesham Nav-Cam 7700 GPS Receiver
My sat nav shows opposite direction map
Binatones run igo. I would recommend finding the latest software and trying an update - then see if the problem still occurs. There is also a setting in the map view for making the map change to the direction of travel - this may be causing an issue.
"austech" is a good place to start.
Feb 19, 2010 | Toymax Binatone Carrera X350 Car GPS...
Sat nav stopped working
Mercedes commans sat nav version 4.1 for E220, is saying off road, and when at home is showing on map that I am somewhere in the National Park Peak District. I have been told to remove fuse for sat nav should be no 28 but in boot of car near sat nav cassette fuses in box only go upto 20. Am I looking in the right place?
Jun 30, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Nav system on 2005 330 xi will not take new addresses
Try to check the region make sure it is under lower 48 states and check the map data base version if the map is outdated try to download the updated map date base.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | 2003 BMW 330
BMW X3 satnav showing incorrect position
there is procedure to adjust that , visit your bmw dealer
Feb 21, 2009 | 2009 BMW X3
Nav system map frozen in Manhattan. Car is in Florida!
Did you try to reset it? top right corner small hole use a pen or paper clip to reset
Jan 20, 2009 | Pioneer AVIC-D3 Car DVD Player
Sat nav maps/gps not working on MIo 268+
Turn the device off( from the back button) press volume up and the flag button( third from the right) in the same time and power on the device. Keep pressed the two buttons untill a screen shows . Press ok and then another ok. Then restart the device. This will do it
Jan 07, 2009 | Mitac Mio 268 Car GPS Receiver
Pioneer AVIC-D3 Car DVD Player Logo
97 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
