Sharp Notevision XG-NV6XU Multimedia Projector Logo
Question about Sharp Notevision XG-NV6XU Multimedia Projector
Having problems with my sharp notevision XG-C40XE
Sir, i m using sharp noyevision for last 3 yrs .............now i have a problems with the lamp most probably.it is switching it on but no display or rays comes out of my projector..............please help me.............
Posted by Anirban on
Anonymous
  • 20 Answers
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Posted on Jul 20, 2009
1helpful
I'm looking for the service manual for a Sharp XG-C50X
To my knowledge this manual is available on paper only. What is the problem you are trying to solve? Perhaps we can help you to solve it.
Dan
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
I have an old video projector, a SHARP XG-C40XE, and I was told that there is no immediate need for a replacement lamp after 2000 hours. Instead of changing the lamp, you can simply reset the built in...
I would replace the Lamp. Too many times I have seen people reset the Lamp Timer and when the Lamp explodes, it also causes the Ballast to fail. At that point it may not be repairable due to parts not being available or the cost of them being through the roof.
Contact Sharps Customer Service and see if they could hook you up with a Lamp and the Lamp Timer Reset info.
That is my recommendation.
Skyassoc
Missing remote control and projector keylock is on
I think you need remote for above said process.
Get original Sharp remote for XG-P10XU from Sharp Accessories.
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
XG-C50
pls check the fans under the Optical Engine, under the prism
the fans easy to be failed
Have a nice day!
Jerry
Lampdeng Limited
2answers
Sharp notevision XG-MB70X
No special tools needed. these units (dlp projectors) are designed so the lamps and color wheels can be changed out by the user. Some can figure out how to do this easily without instructions but to be safe just do a quick search and find step by step instructions. You can also refer to your owner's manual.
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Ekse
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
