Message ''unable to connect'' i do not use a provider....
When I start my desktp I get the message ''unable to connect''. I do not use the PC for internet thus do not have a need a provider to connect to.It will not go past this message.
Re: message ''unable to connect'' i do not use a...
Is it a dialouge box that appears?
or it says "unable to connect to the server host not found"?
please describe little more.
if its for internet, simply go to Network connection and disable "local Area Connection"
If you are unable to connect to internet. There are few things you can try:
1) Reinstall the Ethernet drivers. Go to control panel> add/remove programs> uninstall the Intel or Realtek Ethernet drivers.Then reinstall the drivers from the motherboard disc provided with this pc. Make sure you install only the ethernet drivers.
2) If your pc is giving any kind of error message like limited connectivity then its a problem with your ISP(Internet service provider) or the windows operating system itself. Call your ISP and let them check the issue if they can't help go for a repair install of windows using the disc.
JUST INSTALL THE DRIVERS FOR UR AUDIO DEVICE, IT IS AVAILABLE IN THE MANUFACTURER'S OR MOTHERBOARD CD PROVIDED U WID UR MACHINE.. OR ELSE JUST GIVE US THE MODEL NO OF UR DESKTP OR UR MOTHERBOARD..
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article.
This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
Click Start, click Run, type ncpa.cpl, and then click OK.
Click Network Connections.
In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
Double-click Wireless Zero Configuration.
In the Startup type list, click Automatic, and then click Apply.
In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base:
815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP
313242 How to troubleshoot wireless network connections in Windows XP
If you mean that nothing happens when you push the on/off switch, then most likely your power supply is bad and must be replaced. This assumes, of course, that you have checked the power at the wall and the cords are correctly connected.
If you receive an error message that you are unable to connect to the server, it means that you have one or more ports blocked on your internet connection, either by your Internet Service Provider, or if you are using a router, by your modem with router function or firewall software.
I believe that the problem is either with the service provider not receiving a strong enough signal therefore not sending the picture, or with the service providers delivery route number that may be incorrect. Call your service provider, they should be able to send your phone a service message that in turn should fix your problem.
Hope this helps
