Question about ASUS A7V133 Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Asus a7v 133 motherboard installed a pci sata raid card to operate a dvd rewriter which requires sata. Has picked up the card and installed drivers problem is when i attach the dvd drive, which it shows has been attached when you boot up,comes up with boot disk failure. Anybody have any suggestions?
Posted by whistler1410 on
  • whistler1410 Mar 26, 2009
    Hi Mike thanks for the reply changed the boot up process but still boot disk error message. When I boot up shows dvd writer is attaced to card but doesnt seem to show on hardware in the bios. Is there something else I have to change have tried to update bios for the motherboard but cant get it download. Any suggestions would be great thanks Robert.
Anonymous
    President:
  • 2,351 Answers
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Posted on Mar 26, 2009
  • Anonymous Mar 26, 2009
    Hi Robert,
    checked Asus for bios update.
    A7V133 Beta BIOS 1010.01B, 2003/03/21 update.
    (Support 48 Bit HDD). This bios update will not help your issue.
    It's recommended never to flash your bios unless your sure it will correct an issue.
    The max data transferable bus speed of this board is 100MHz. Even if you attach a SATA drive, DVD or Hard disk drive your locked in by the motherboards bus speed. The motherboard uses an ATA 100 controller. When you added the PCI SATA card to your system you added another controller. Your board can only support the controllers built into the board.
    Are you using both IDE ports? How many IDE drives do you have in the system & include IDE CD/DVD drives.
    (Do not include the SATA writer. My bet is that all the current motherboard controllers are being used. Most likely this is why the "bios" does not see the SATA PCI card or more importantly the DVD writer. If you had a SATA hard disk drive & connected it to the SATA card I'll bet the bios would not see the SATA drive either.
    Now you should be able to use the adapter at this next link for your SATA writer but You'll need an opened IDE port.
    http://www.buyextras.com/coata66hadrt.ht...
    Here is the Google search link;
    http://www.google.com/search?hl=en&q...+
    I have come across this issue before. Getting too old & forget from time to time. If you want 100% confirmation of this you can call Asus tech at: 1-812-282-2787 IL U.S. M-F 8:00 to 5:00PM.
    Do not use your manual, its too old & the above number is correct. Oh & by the way, Asus web site is one of the most used sites on the web, other than Google. There is a chance that the IDE to SATA controller will also not show your SATA DVD writer in the bios.
    Keep me posted Robert!
    Mike
  • Anonymous Apr 08, 2009
    Robert,
    please call Asus tech. This issue should work. Your board uses controllers to run IDE ports & PCI ports. Ask to pro's. You can call Asus at the above number I listed. You should be able to download the Beta bios: A7V133 Beta BIOS 1010.01B
    Support 48 Bit HDD.
Asus motherboard problems Installed a new F2A55-MLK series to replace old ASUS board. Running XP and when I install the HDD it boots until the starting windows screen and get blue screen Asus tech no help.
go into the BIOS setup and find settings for SATA operation or something similar. the available options should be
1. Native SATA/IDE
2. AHCI supported
3. RAID
windows xp was installed with SATA support but requires special drivers for AHCI or RAID, so you should set your computer's SATA operation to native or IDE in order to solve the problem.
Additional tip:
next time you manage to boot to windows, boot to safe mode (boot while pressing F8), so you can review if all the drivers are well installed in device manager.
Oct 12, 2013 | Computers & Internet
Tip
Problem Using Windows Install Disc with RAID? Some Tips:
After going through some issues installing Windows onto a RAID partition using this Motherboard, I found some things that were helpful.<br /><br /><span style="font-weight: bold;">#1 Install hangs, or I get an error after Installing RAID Driver.</span> Nowhere in the manual does it tell you this (or at least I didn't see it) but when you install the RAID driver during the windows install, the Motherboard automatically sets SATA connectors 1, 2, 3, and 4 to be RAID. That means if the DVD/CD Rom you are using is plugged in to any of those connections, the minute you install the RAID Driver, the Optical Drive will no longer work. You have to use SATA 5 connector on the motherboard for your optical drive<br /><br /><span style="font-weight: bold;">#2 Multiple Optical Drives with RAID</span>. Because of the issue in #1, there is really only 1 internal SATA Port you can plug an Optical drive into when you have RAID configured. There are some solutions if you want more than 1 Optical Drive alongside your RAID configurations. <br /><br />You can use the ESATA port on the back of the Motherboard with an extra-long SATA cable. If your case has grommets on the back for water-cooling lines, you can run the cable through there, or just in an unused PCI slot on the back.<br /><br />You can use an old-school PATA DVDrom. If you are installing 2 Optical drives, and one is a DVD burner or reader, you could get a PATA DVD Burner or reader instead. This Motherboard does have a good old fashioned ribbon connection, so it's possible. Typically DVDs or CDs don't move enough data to see a difference between PATA and SATA, but when you start getting into any DVD reading/Writing above 8X or so, you will be throttled.<br /><br />Get a PCIe controller card. I think of this as the last resort for this board because of it's possibility with graphics cards. Hooking up anything unnecessary to any of the PCI slots would be defeating the purpose of having 2 full 16X PCIe slots. You might be able to squeeze one in on one of the 1X connections, or maybe the bottom full slot, but it could get cramped if you have 2 or more Video cards.<br /><br /><span style="font-weight: bold;">#3 Windows Installation Issues. DVD Drive Stops Reading during install.</span> I had this issue even after finding out my issue from tip #1. I found that some windows install discs mixed with some manufacturer's DVD drives don't get along well. It would start the installation OK, and get most of the way through it, then it would hang and throw up an error. It seems that during Installation, the SATA DVD drive decides that doesn't like the generic drivers anymore, and just stops working. I fixed this by pulling a PATA DVD drive out of an older PC to use until Windows was fully installed. Once Windows was installed, I pulled that drive back out, and Installed my SATA DVD drive, and Windows installed the drivers with no problems.<br /><br /><span style="font-weight: bold;">#4 RAID Performance. </span>I'm not too sure that I'm getting the best performance from this RAID-0 configuration. I'm running 2 WD Caviar Black 500GB HDDs. My Windows Experience score for the drives is still 5.9. Perhaps the RAID configuration would work better with some faster drives, like Samsung drives, or WD Velociraptors... But I'm unsure.<br />
on Apr 03, 2011 | ASUS M4A79T Deluxe ( M4A79T DLX MB PHENOM...
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Suggest Hard drive for ASUS K8N Motherboard
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Nov 14, 2010 | ASUS Computers & Internet
New sata harddisk not detected
The mother boards from that time you had to install the RAID drivers to use SATA drives. The drive disc which came with the mother board should have the drive, but I would suggest going to ASUS's web site and download the latest drivers. Click the link below, Select which OS (Operating System) you are using, Next click the little + box next to "IDE" and the drivers needed will be listed.
http://www.asus.com/product.aspx?P_ID=xCBogxJhh6yWBQRi&content=download
Jan 26, 2010 | ASUS P4V8X-MX Motherboard
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
I have a asus AV7 with a amd 64 bit processor 2 gigs of ram windows Xp Pro 7 dvd burners NEC 16x and 2 120 gig 133HZ.sata drives and 4 133 ATA hard drives 133 maxtor 120 gig configured in a raid stripped 0...
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Sep 10, 2009 | ASUS Computers & Internet
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Motherboard
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Oct 09, 2007 | HP Pavilion 513n (P9850A#ABA) PC Desktop
ASUS A7V133 Motherboard Logo
1,671 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
