The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
GE's ice makers are harvestable, means you can manually tell the ice maker to harvest or cycle. Turn ice maker off, went 5 seconds, turn ice maker back on, tap the paddle 3 times (push the paddle inward completely) then it should cycle, may have a delay like 20 second. I hope this helps.
Unplug Ice maker from plug on inside wall, remove and let thaw. Don't worry when removed the water will not enter the freezer. Let me know if this works as I get very little support from LG. Thanks, Se Breeze
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
