Question about Intertherm P3RA-048K Air Conditioner
Model p5rd-048k blower motor turning very slow no air from vents
1 Related Answer
mpcheeseman1
mpcheesman1
  • 1400 Answers
SOURCE: we have a hvac Nordyne model P3RA-048K Everything
Hello
Either the filter is clogged and needs to be repaced.Or check the coil inside the unit and see if it is getting iced up.You can try shutting the unit down for an hour or raising the temp.If this helps the motor speed then you know the coil was iced up.
It is also possible the motor may be going bad,doubtfull though since they will run for a while then shut off.
Check your filter
Check for ice
Possibly clean the inside coil.
Posted on Jul 31, 2011
AC fan blows less air after extended use
Sounds to me the blower motor is on it's way out and should be replaced. Even though they sound like there working doesn't mean everything is ok with it there are different parts on it that could go wrong and they way to fix it is with another blower fan and not a bad idea to do the resistor at the same time located in the blower box with about 4 wires coming out of it with one or two screws holding it in place all is located under dash behind the glove box area.
Aug 03, 2012 | 2002 Dodge Grand Caravan
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
Model e2eb-015ha elements cycle on and off, but blower motor never comes on;a/c side works fine
R u saying that the blower motor works for the AC but not for the heat. If thats the case then u have a t-stat or control board problem. u can jump the red white and green wire from the tstat. if that works then then tstat needs to be replaced if not the control board is the problem.
Oct 21, 2011 | Intertherm P3RA-048K Air Conditioner
E2EB-017HA HOW TO SLOW SPEED DOWN ON BLOWER
Go to the blower motor find 3 wires.Black is high,blue is med, red is slow. Find what wire is on blower relay. then adjust to what you what. hope this helps.
Aug 21, 2011 | Intertherm P3RA-048K Air Conditioner
Air is not coming out of vents like it should. Could I possibly need a new blower motor?
Hello, it is possible that either the blower motor is running slow due to a weak capacitor or the blower motors bearings are giving out. I would replace the capaitor first since it is less expensive and see if it helps, if not the motor will need to be replaced. Also, make sure the filter is clean, blower wheel is clean before replacing the capacitor. Sometimes dirt will cause the wheel to turn slower.
Aug 03, 2011 | Heating & Cooling
We have a hvac Nordyne model P3RA-048K Everything
Hello
Check your filter
Check for ice
Jul 31, 2011 | Intertherm P3RA-048K Air Conditioner
2000 jeep grand cherokee, only blow out a little air even when the blower on hi,,you have to put your hand next to the vent to feel the air
you may have had something fall down into the defrost vent and it has worked its way down and is blocking the air flow thats trying to come out the vents,near the blower motor.also does it sound like the blower motor is spinning on high speed or at a lower speed,you could have a slow turning blower motor.
Jul 20, 2011 | 2000 Jeep Grand Cherokee
Interherm Model mmhb-09oabhp-06 During cold and on windy days the main blower starts then pauses, starts again and pauses, starts again and pauses, then finally turns on and runs.
the motor is working hard on start-up. could be the capacitor is going bad I would start with the capacitor and if that doesn't fix it the motor is prolly going to have to be replaced.
Dec 07, 2009 | Intertherm P3RA-048K Air Conditioner
My intertherm furnace (old model) has recently getting quite loud and clunky during its heating cycles, sound like the blower maybe??
Your blower motor has several speeds to it and by the problem you are having it sounds as though the blower motor may be going out. The motor has a slower speed for the heating cycle and since you have the noise in the heating mode I suggest having the blower motor changed as soon as possible since it could cause other problems in the heating section of the furnace( possibly burning out the high limit switches). Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Intertherm P3RA-048K Air Conditioner
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
