Old washer, never had a problem. Washed two loads last Thursday. Had friends using the house over the weekend. They said the first load they tried washer doesn't work. Not sure what they did, but it just buzzes instead of pumping water. Can't get it to respond to anything - won't just spin, etc.
SOURCE: Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
SOURCE: When the washer gets to the spin dry cycle, the
Thanks for choosing FixYa and welcome.
Testimonial: "Just having someone offer suggestions or solutions is very helpful. It helps to know I am not alone in trying to resolve a problem. Love this site!"
SOURCE: My whirlpool washer won't drain and spin. It is 10 years old. Fix or repair? Please say fix!!!
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. You can usually look and visually see the spot where the switch should be and if damaged. How to repair :
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off. The lid switch will be attached to this portion so located it, remove the two screws that hold it in place, under the lid, and swap out with a new one. This is a cheap repair, just take your time and you'll be fine,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
