Sony SLV-D380P DVD Player/VCR Logo
Laurie Groves Posted on Mar 25, 2009
No picture on tv when playing dvd or videos
I have no picture on tvbut i can hear video and dvd running when i plug another device into the same inputs it works
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
130
Points
I had the same problem, no sound. Just a picture. Check the cables you have running from the VCR to the TV. They may be plugged to the TV incorrectly.
1helpful
No capture picture from VCR - honestech VHS to DVD 3.0 SE
VHS to DVD 3.0 software.
In Options Menu, configure as follows:
Video: AV to USB
Audio Device: XX(AV to USB)
Format:DVD
Video Type: NTSC
Quality: Best
Split Size: choose GB.
Output folder: xxxxxxxx
Click OK, then play VHS, then press record button, then after finishing press stop.
Important: tolerate the image cannot be previewed so if you only hear sound then after sopping recording and playing it in another videoplayer you will be able to watch it. ; )
Julian C
2answers
VIZIO P50HDTV10A PICUTURE FLICKERS IN AND OUT CONTINIOUSLY WHILE WATCHING TV. PICTURE DOES NOT FLICKER IF WATCHING VIDEOS.
HI, you can do these troubleshooting steps and get back to me..
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Could hear the chanels good but no pictuere
Hello
1. Check the video connection of any devices plugged into the television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
2. Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
3. Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
4. Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
5. After all the steps and it does not come on then you would need to visit a technician.
BEST OF LUCK
Why is dvd player not transferring picture to tv screen
Did you hear the sound of the video that you're playing in the dvd player? The problem might be in the rca plug that you are using. Try to check if the plugs are properly installed in the right positions.
1helpful
Cant see dvd picture but can hear sound on tv
check the video jacks make sure it is properly fitted if it still don't work remove and plug the video jack again or clean the two end of the jack and the video jack slot on your tv and player or replace the jack. If it still don't work. try other dvd or the device has a problem.
It doesn't work on my ps3 no picture only audio
If it works on other televisions, than the video cord must be good. Is the television on the right input channel? If it is, the video input may be bad. You should test the video input with a dvd player or vcr. You can always plug ps3 into a vcr, and vcr up to televison.
How do I hook up my magnavox 510 700watt DVD player and sorund sound system. My TV does not have a S-Video plug in the back it is a 27" symphoinc tv. I just have the cable plug in screw on and the 3 plugs...
you will need an rca type cable to go from your dvd player to the tv. you should be a able to find one at your local walmart for around $5
simply connect the cable to the yellow input on the tv and the yellow output on the dvd player, then change the input to your auxillary source.
I can hear the dvd playing but cant get a picture
Make sure the video cable is plugged into the proper spot on both TV & DVD player. 2nd. Try cleaning with a good quality DVD cleaner. If this still doesn't solve the problem replace the video cable. Hope this helps & please remember to rate my answer. Thanks.
1helpful
2answers
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Only voice no picuter while playing DVD
make sure the video cable is plugged in correctly, or if it is damaged.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
