Question about Vacuums
Dyson dc30 charging issue
I've got a 3 year old dc30. Few month ago my battery died, so I bought a new one from dyson Australia website. I received it today by mail. I connected it to my dc30 and pressed the button to see if it runs. It worked. But when I put it on charge the green charger light was staying on only for 20 minutes. Usually full charge takes about 2-3 hours. Please advise on where the issue might come from. I'm really confused.
Posted by Ross on
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Posted on Jan 10, 2009
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Posted on Mar 21, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: I noticed my run time was getting shorter and
To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
Happy Holidays The FixYa Team
Posted on Dec 18, 2010
small6363
  • 18429 Answers
SOURCE: dyson dc 31 was working
check all conections are clean on the battery terminals,this link is for the manual,
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc31_origin_manual_uk.pdf
Posted on Apr 16, 2011
askdyson
AskDyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: We push the trigger, and the light comes on but no suction/ motor not working
    I'm sorry to hear you're having difficulties with your DC35. From what you've described, it sounds there may be a fault with one of the components of your machine. If you give our Helpline a call, we should be able to help - you can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call so we can run through some troubleshooting over the phone with you.
    We'll look forward to helping you resolve this issue.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Mar 15, 2012
    I have a Dyson model DC30 which runs for a few seconds and then shuts off, is there a solution out there
    Hi there, it's Jack at Dyson.
    I'm sorry to hear your DC30 seems to be working intermittently. In order to confirm which part may be at fault we'd need to take you through some simple diagnostic checks.
    When you have your DC30 fully charged and near to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
    Aug 19, 2014 | Dyson DC34 DC30 DC30Handheld Vacuum wall...
    My DC35 keeps cutting out ie every 10secs. The filter has been washed and the machine is clear of any obstructions. The battery is fully charged - Graham
    Hi Graham, it's Jack at Dyson.
    If your DC35 seems to be cutting out frequently in use, and you're confident that there are no blockages and the filter is clean, it would be worth contacting us directly for some further advice.
    When you have your machine fully charged and easily to hand, our experts will take you through some diagnostic checks to determine which part may be at fault. If your DC35 is within our 2-year cordless guarantee period, and has been used and maintained as described in the user guide, we should be able to replace the affected part for you.
    You can reach us by calling the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    May 26, 2014 | Dyson DC35 Handheld Vacuum
    Best wishes,
    Jack
    Mar 14, 2012 | Dyson DC35 Handheld Vacuum
    Dyson animal died while vacuuming and will not turn on now?
    I'm sorry to hear you're having difficulties with your DC17. Your machine is equipped with a safety device which shuts the cleaner down to prevent overheating - this is often due to a blockage, or because the filter needs a wash.
    The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
    In normal use, the filter should be washed at least once every 3-6 months. I note you've already cleaned the filter, but you might want to watch the video below to check you've done so as recommended. Use cold water without detergent, and allow at least 24 hours for the filter to dry completely before replacing it.
    This should resolve the issue, but for any further assistance or advice, please call us free on 1-866-693-9766, or email us at [email protected]
    Best wishes,
    Jack
    Jan 16, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
    While trying to clean brush of Dyson DC33, tried to remove the main turbine, got one side out but cannot get it back in now.......PLEASE HELP!
    Sorry to hear you've had a problem with your DC33. I note you posted the question a few months ago, so hopefully you've managed to resolve your issue by now. If not, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so we can assist you.
    Kind regards,
    Jack
    Dyson Customer Service
    Mar 19, 2011 | Dyson DC33 Bagged Upright Vacuum
    My dyson slim scope does not have any suction at all. i"ve checked the tubing for any clogging, and there is none. What can it be?
    Sorry to hear you've experienced a problem with your DC18. I note this question was posted several months ago - hopefully you've resolved your issue since then. If not, you may find it helpful to visit the Support section of our website. These simple steps should help you determine whether everything is correct with your cleaner:
    http://www.dyson.com/support/help.asp?article=1453&product=DC18-ALLFLOORS
    If you've tried this and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some simple checks over the phone.
    Kind regards,
    Jack
    Jan 17, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
    The brush is not turning at all
    Sorry to hear you're having a problem with your DC18. I note that this question was posted several months ago. Hopefully you've resolved your issue since then. If not, you may find it helpful to visit the Support section of our website, and follow these simple steps to make sure everything is correct with your machine:
    http://www.dyson.com/support/help.asp?article=1050&product=DC18-ALLFLOORS
    If you've tried this and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
    Kind regards,
    Jack
    Jan 15, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
    My dyson DC16 constantly shuts off even when battery is fully charged. I cleaned the filters to see if that was the problem. It only runs for a few seconds before it shuts off. It will run intermittently...
    Hi its Darran at Dyson.
    From your description of the problem, it sounds as though there is a problem with the battery.
    Your DC16 will have been supplied with a 2 year guarantee. If it still within this period, please contact our Helpline on 0800 298 0298. However if your machine is no longer covered, a replacement battery can be purchased via our website at www.dyson.co.uk/store.
    Kind regards
    Darran
    Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
    WST1600 upright
    Hi , check battery teminals might corroded need clean the post ,unscrew clean and try to charge , if does not full the battery have problem , need to replace.
    Jan 21, 2008 | Westinghouse WST1600 Upright Vacuum
    Vacuums Logo
    579 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
