Washing machine gets to rinse cycle and an error appears at 13 minutes remaining. I turn off machine ad turn back on select spin and it comes back on at 10 minutes remaining and completes cycle. I have unplugged from power for several hours to reset the mother board but it makes no difference
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Thanks ill have to check it out. I just did a cycle and it stopped again the fault code is 1E. It slowly puts water in to the tub but it almost sounds like its struggling to put water in. Then it errors after several minutes on that stage of cycle
Prior stages to this tho it fills and empties fine
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
