Hi , it prints what i send correctly but after that doesn't stop , and feeds white labels out until i switch off. please help me...
U have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Testimonial: "hi thanks, but it doesn't work . at printer properties ,preference , i input correct size 55*50 with gap 2.5mm , and i get a test page correctly... but it doesn't stop again . this problem is on with all ports USB or com port . i think it should be from gap sensor . isn't it? "
which program using?
any special program , from start--> all program --> printer and faxes -->
printer properties --> test page and it print test but... doesn't stop and labes comming out and out
You have to clean install with updated driver
i test it from windows , i want just a correct print
not again , thanks Joker . i belive that i have hardware problem on it's gap sensor
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
