Question about HP OfficeJet 6110 All-In-One InkJet Printer
Wont connect to recieve fax
Will ring but fax will not connect or answer
Posted by lanaisthebos on
Anonymous
  • 104 Answers
Make sure your fax machine is on and ready to receive, you may have to configure it first, see your manual .
when it rings, raise the handle and wait until you get the fax tone, let the other person wait as well, you press the green, go or fax button, then they hang up, and the fax goes through.
Posted on Mar 26, 2009
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
WE CAN SEND A FAX BUT CANNOT RECIEVE A FAX THE PHONE LINE IS CONNECTED TO LINE AND NOT PHONE PLEASE HELP
try setting the answer mode to auto answer. It may be in manual answer mode. Also try calling your fax number and see if it rings.
Feb 19, 2011 | Canon FAXPHONE L80 Laser
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Not recieving fax
Try This
Goto to Setup (on the printer) Fax settings Check The ECM(Error correction mode) : It should be off ; DRP(Distictive ring patern): ALL Rings; Rings to answer 2 (dedicated) ; 6 (Answering machine ); There should be no voice mail service activated otherwise you won't be able to recieve fax; Try getting fax it should work;
Regards
SOumajit
Aug 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
CAN'T RECIEVE FAXS
Make sure the Auto answer the button is on....
Or
Reset the printer setting to default and set the rings again to 3...and try..
Jun 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Answering machine turns on and I can't receive faxes.
Why don't you consider a separate Phone/Fax switch. It will answer first ring and detect a fax and then ring the fax/printer you can set that to one ring as well, otherwise it ring the answering machine that is plugged into that and you can set that to answer on 3 or 4 rings. Then you have time to pickup phone if you are available.
Thanks what I do. The boxes are about $30 They are fairly cheap.
Nov 24, 2007 | HP LaserJet 3055 All-In-One Printer
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Fax
Press setup on the All-in-One. Navigate to Advanced Fax set up using arrow keys. Select Answer Ring Pattern and set it to All rings. Get back to me if the issue persists with detailed description.
Oct 22, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
95 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
