Question about Sony NW-E002BC Walkman MP3 Player
Can't connect to computer with NWZ-A816 Sony walkman.
It says that it is chargin and it does but it doesn't come up so that I can download music
Posted by myeshamoore on
  • Anonymous May 20, 2009
    nao consigo reproduzir mp3
Anonymous
I figured it out!
It used to be that when I plugged my walkman into my PC, the screen would read "connecting" but would never actually connect, so I couldn't add/remove songs from the walkman or even recharge it. The solution is easy. Plug your walkman into your PC, and then go to
Control Panel --> Device Manager --> Portable Devices --> Walkman
If you have the same problem as me, the Walkman icon will appear with a yellow exclaimation mark, signifying a problem. Just right click the icon, and selecte "Uninstall". After that, the driver will be removed from the PC. Now, unplug your walkman from the PC, and then re-plug it in, and the driver on the Walkman will automatically upload to the PC, and everything should be back to normal and the Walkman should work perfectly.
The problem is that the Walkman driver in the registry was partially damaged somehow (I think during a registry clean up I did earlier). Just uninstall it, reinstall it by plugging in your walkman to the PC, and voila. Let me know how it works for y'all!
Mike
Posted on May 03, 2009
John Head
    New Friend:
For anyone out there still experiencing this problem, here's a suggestion. I bought a generic USB cable to have as a backup for my Walkman. It worked fine, and I got used to using it all the time. Recently, I was unable to connect the Walkman to any of my computers. I tried every piece of online advice I could find. Nothing worked. Then I went back to the original USB cable that came with the Walkman. I plugged it in and it worked. The generic cable still works to charge the device, but it will not connect otherwise. Basically, I'm advising that you make sure the problem is not with the cable, even if you're using the original. Good luck. John
Posted on Nov 20, 2012
1 Related Answer
Anonymous
SOURCE: sony walkman nwz-a816 getting usb device not recognized
okay, try plugging it in. Go to Startmenu, right click 'My computer', and select properties. Go to the 'Hardware' tab, then Device manager. Down at the bottom, you should see a section of the tree that can be expanded, entitled 'Universal Serial Bus Controllers' Find the Unknown device part. Select that, then go to 'Action','Uninstall'. After un-installation, the computer might restart. Unplug your walkman. When windows is back up, plug it in, and see if that works. if not, I have an alternative solution
Posted on Sep 09, 2010
Problem connecting walkman to computer
Once you have added files in one mode, those files cant be changed in the other. Solve your MP3 Player Connection Problem.
See my tip posted here about this problem. Now Sony has 2 programs on their site for the walkman. One is called "Content Transfer" the other is called "Media Manager for Walkman" Check out these programs see if they help. Lastly, on the back of the player Is a small hole the tip of a paper clip will fit into to reset the player, try that if all else fails.
Mar 05, 2010 | Sony Walkman Video NWZ-A816 Digital Media...
I want the software for the sony walkman nwz a816
Hi There !!
When you say need software for Sony NWZ A816. I have a link for downloading the drivers. That contains the Media Manager for the device, Firmware and Sony Applications.. Choose either one..
Link is given below..
http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZA816
Please revert for further clarifications.
Feb 02, 2010 | Sony Walkman Video NWZ-A816 Digital Media...
Sony walkman nwz a816 froze.
you can try formatting it and if that doesn't work try replacing the battery.if you don't know how to format email me at [email protected] would try to format it first.(you will lose all of your songs but i will tell you a way to get free music fast and easy
Jun 29, 2009 | Sony Walkman Video NWZ-A816 Digital Media...
Nwz-a816 sony walkman how do i put videos on it
http://www.youtube.com/watch?v=cI41SLayVfg thats your answer
Jun 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
How do I find out how to download and delete songs on my Sony Walkman NWZ-A816?
just use limewire to get songs u want then you can use windows media player to delete or put songs
May 13, 2009 | Sony Walkman Video NWZ-A816 Digital Media...
Sony walkman nwz-a816 getting usb device not recognized
Dec 30, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Mp3
if it doesn't sync, don't worry just open the folder where the music files are stored on your computer, connect your Sony Walkman to your computer and highlight the music files you want to add to the Walkman and select (copy these files) a windows will open for you to select the place you want to copy to, select your mp3 player and click on copy to copy the selected music to your Walkman
NOTE: if you Sony Walkman has a specific folder for music files, you need to move the songs you copied from your hard drive's music folder to the music folder on your mp3 player for the player to recognize the songs in order to play.
Dec 26, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Walkman
Hi...I just found help on the sony support page www.sony.com. You can delete songs by going to MY COMPUTER and clicking on the walkman as a storage device and delete files right from there under the music folder. Your MP3 will update when you unplug it from the computer.
Aug 21, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Sony NW-E002BC Walkman MP3 Player Logo
1,674 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
